Soft Window Fog tricks? - JeepForum.com
post #1 of 12 Old 05-14-2004, 02:46 PM Thread Starter
joeyt17
I was wondering if there are any secrets on how to keep the windows from fogging up on the soft top. Most days its fine, but on a humid or rainy day they just turn completely fog white from moisture and such. The only clean window is the windshield, and the side windows if i wipe them off. any tricks that can help? I am a big fan of being able to see cars out of any of the rear three windows...
joeyt17 is offline
post #2 of 12 Old 05-14-2004, 03:16 PM
bcompton
bcompton's Avatar
Doesn't the defroster work? Mine will clear all windows in just a few minutes.....
01 Sport, front drum brake & birfield joint conversion, custom '4 Wheel Drive' stickers, neon washer nozzles, chrome type 'r' oil pan bolts, wooden bead seat pads, racing exhaust tip, offroad license plate frame,
lots of misc. stuff (2.5" Skyjacker springs, 1" BL, 1"MML, Custom flat tcase & engine skid, RE arms, Skyjacker shocks, JKS Discos, Superlift Trac bars, Garvin bumpers, Warn 9.5ti, Lockright & trac-lock, 32" BFG KM's, Kilby & warn skids, EOR rocker bars, cowl snorkel)
bcompton is offline
post #3 of 12 Old 05-14-2004, 03:24 PM
JSBlu974X4
i use that armour all fog wipes or whatever it is, works good
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #4 of 12 Old 05-14-2004, 03:45 PM
JeepinBlue24
JeepinBlue24's Avatar
Defrost clears 'em in seconds for me. Make sure the insides of the windows are fairly clean, if not it takes a lot mroe to clear 'em. Wonder if it makes a difference since I have A/C. The compressor runs on deforst mode to remove condensation....never though what what happens with non A/C cars...umm have to look at my buddies jeep tonight.
1995 YJ: Just got her.
Planning:
Dynatrac 60s w/SOA
36 or 38 IROKs
..and keeping the 4banger until she dies!
JeepinBlue24 is offline
post #5 of 12 Old 05-14-2004, 05:50 PM Thread Starter
joeyt17
I do have A/C, but even with defrost on high it still never completely defogs. I'll try those armor all wipes, once i get to the store to pick some up. I heard that toothpaste or shampoo can work as well, but i wasn't sure (scuba diver trick i think). just thought i'd get some feedback from the board
joeyt17 is offline
post #6 of 12 Old 05-14-2004, 08:23 PM
Timbo
DON'T use toothpaste! Alot of toothpaste has an abrasive in it (like pumice) and will haze your windows.....a trick used for ski goggles is a light coating of dish detergent.....put a little on a rag and smear a very light coating on the window (make sure window is clean first so you you don't pick up dirt with rag and scrape it across your window). Also there is a special formula called "Cat Crap" (yes that's right) that skiers use in their goggles to keep them from steaming up....I believe you can get it at Campmor (Campmor.com).... it works really good (I use it winter hiking on my glacier goggles) but I thing the soap trick should do you fine. It's cheaper too
Good Luck,
Timbo
Live Free or Die; Death is not the worst of evils
Member: Black Jeep Society
Amateur Radio Call KB1MM
Timbo is offline
post #7 of 12 Old 05-14-2004, 09:20 PM
Cynic
the problem is dew point is met at the windows.....the solution is defrost for the front window and if your trying to get the back windows then use max a/c to drop the relative humidity in the vehicle so there is not as much moisture in the air to condense on the windows.....equalizing temp. with the windows down will help some too if you dont want to use max a/c but the a/c will work the best.....
Cynic is offline
post #8 of 12 Old 05-14-2004, 10:14 PM Thread Starter
joeyt17
thanks for all teh replies, i'll try the tricks out soon such as use A/c and all to lower humidity. i knew there was a reason campmor sends me magazines in excess...i'll check out "cat crap" from there...but will most likely fall back on the soap technique.
joeyt17 is offline
post #9 of 12 Old 05-15-2004, 12:03 AM
PrfctAggression
PrfctAggression's Avatar
If you are into diver's tricks, try spitting on them. It'll at least be better than toothpaste, and I know for a fact it works on dive masks.
PrfctAggression is offline
post #10 of 12 Old 05-15-2004, 12:15 AM
cajunwrangler
cajunwrangler's Avatar
if you do the cat crap idea you have to use the old stuff... anything still warm will surely just fog'm up more.
cajunwrangler is offline
post #11 of 12 Old 05-15-2004, 08:25 AM Thread Starter
joeyt17
Now I tried the "Cat Crap"...but it just clumped away and formed litter critters in the back of my tub. Now I need a way to find a way soften it up!
But it all seriousness, next time i get a free minute i will clean my windows thoroughly and use the soap technique
joeyt17 is offline
post #12 of 12 Old 05-15-2004, 08:56 PM
halfmoonclip
Your defroster is working correctly? I had a broken air door in the Cherokee; it made lots of noise when you set it to defrost, but the air wasn't getting to the windshield.
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline
Those little soft window retainers - YJ soft top. schatenjager YJ Wrangler Technical Forum 1 11-17-2008 03:25 PM
Tricks for getting the rear window back in? anrolenator TJ Wrangler Technical Forum 19 09-14-2008 09:26 AM
Any tricks on soft top install? coloradokid JK Wrangler Technical Forum 19 03-11-2008 09:31 PM
Buggered Rear Window Zipper... Any good tricks? azcoyote TJ Wrangler Technical Forum 7 12-06-2007 08:40 AM
Soft top Window out ?? Jeepsrfun TJ Wrangler Technical Forum 14 03-12-2006 08:55 AM
