Soft top window-sill won't stay in - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Soft top window-sill won't stay in
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep seats at Jeephut.comEngo winches available at www.rockridge4wd.com! Free shipp
Unread 01-08-2005, 07:19 PM   #1
MikeWL
I've heard mention that this is a typical failure mode on aging soft tops, but I'm hoping there will be some suggestions to get me through another year or so.
Anyway, the problem is that all of a sudden I can't get one of the little plastic window sill on the passenger side to stay in the slot. It pops out and then starts rattling against the door surround. Driving me crazy!
Any suggestions appreciated!
2000 TJ Sport - 4.0L, 5-sp, Dana 44 LSD, 3.73 gears, Dick Cepek 150Wx4, 32x11.5, Warn x8000i, REBB, Goferit 1" MML, flat-towed often
MikeWL is offline   Reply With Quote Quick reply to this message
Unread 01-08-2005, 07:59 PM   #2
KD5LEF
Did you loose the insert?? That would cause it.
1 Divorce.....countless $$. 2004 Jeep Rubicon - Armored, lifted, new tires, wheels, tire carrier. Winch to come - PRICELESS!!
3inch OME, JKS goodies, 1.25BL. 33x12.5 BFG KM2's
KD5LEF is offline   Reply With Quote Quick reply to this message
Unread 01-09-2005, 12:57 PM   #3
MikeWL
You mean the L-shaped plastic piece that goes in the slot? That's what I'm talking about, it won't stay in the slot.
I tried cleaning out the slot with rubbing alcohol and it seems to be a bit better. My last hunting trip was very muddy , so I'm wondering if the dirt up in the slot may be making it slip out. ????
