soft top upper door water leak? - JeepForum.com
post #1 of 8 Old 05-14-2002, 07:58 PM Thread Starter
weslaine
Anybody else have this problem? If so, please let me know if you've found a solution.
During heavy rains, water drips into the upper half of my soft top doors. Somehow, water gets trapped in the canvas gusset around the plastic windows. Eventually, it overflows and leaks down into my map pockets, through the holes and onto the driver side and passanger side floors. It can turn into 2-3 inches of water on the floor. I can literally take my upper doors out after it has rained, turn them on their sides, and about a liter of water will come out.
97 TJ Sahara Black
weslaine is offline
post #2 of 8 Old 11-09-2002, 02:56 PM
rbowling
rbowling's Avatar
I have this same problem with my 2002 TJ..Anyone have any Ideas on how to fix it? I brought it to the dealer and they pretty much told me "it is a jeep thing" It is getting to be a pain...
Please let me know...
Richie
02 TJ - Black
Stock...for now !
rbowling is offline
post #3 of 8 Old 11-09-2002, 03:18 PM
Tango
Tango's Avatar
you know a LOT of Jeep owners complain of water on the passanger side of the Jeep I never really looked at this but next time it rains I am going to go look and check mine for any water problems. if I have any problems I will stay on top of it and try to get you guys some answers
just my 2cents
Brian
02 TJ 4.5" of lift , Locked Both ends, with 4.56's pushing 33X12.50 MTR's
Tango is offline
post #4 of 8 Old 11-18-2002, 02:36 PM
Bob J
Bob J's Avatar
1984
I'm very familiar with the water on the front passanger side (and sometimes the driver side too) from my YJ and the water getting in the vents...
I just checked today while cleaning my Jeep out and my passanger side rear floor is soaked.. I have full doors.. I'm currently searching for the solution
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #5 of 8 Old 11-18-2002, 02:54 PM
macb
macb's Avatar
There are already several posts regarding this type of problem
on the softops - and several possible sources, mine was the
seam on the soft top itself, many have water coming in through
the vent (there is a fix for this by the way), there was one guy
who found the water coming in through his step shield.
do a search in this forum for 'rain' and you should see plenty-o-info!
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #6 of 8 Old 11-18-2002, 04:22 PM
4cornerzJeeper
4cornerzJeeper's Avatar
I don't understand where your water is accumulating. From the outside????
Maybe you could post a pic of the problem area you believe is the sourse of the water build-up. and then we may be able to all come up with a solution?
Try bending the upper doorframe in some to make a tighter fit around the door surround. Use a paper hole punch to make a small hole at the low end of the canvas gusset around the plastic windows your describing.
97 Sport, 5spd, RE 5.5 in my closet, under bed, stacked in corners, and 35" MT/R's on balcony waiting to be installed. I'll have it done by the 2nd week of jan 03.
http://community.webshots.com/user/beadlocks
4cornerzJeeper is offline
post #7 of 8 Old 11-18-2002, 09:12 PM
Bob J
Bob J's Avatar
1984
I see alot of people complain about water in the back.. but no solutions...
only solutions are for water coming in through the vents which is not the case here...
I noticed it while it was still raining and the door frames were dry, and the inside of the softtop was dry... oh well, hard top goes on tomorrow anyways...
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #8 of 8 Old 03-09-2012, 02:34 PM
SKIQUATTRO
just called my dealer to see if they had PN 68003655AB so i can repair my leak before summer comes
$131.00 for some rubber and foam???
dont think so..
SKIQUATTRO is offline
soft , upper , door , leak
Soft Upper Door Cut gumby885 YJ Wrangler Technical Forum 0 10-23-2009 08:44 PM
Soft Door Upper Fitment osudelt69 TJ Wrangler Technical Forum 11 12-19-2007 05:51 AM
Soft Upper Door Window Mod BeachCrawler TJ Wrangler Technical Forum 9 12-20-2006 08:46 AM
soft top upper door mudcat425 TJ Wrangler Technical Forum 3 01-14-2006 08:06 PM
Can I get just the skin for soft upper door? James3374 TJ Wrangler Technical Forum 4 05-20-2002 10:17 AM
