Soft Top Repair...A Mini Write-Up - JeepForum.com
post #1 of 12 Old 07-20-2006, 12:50 AM Thread Starter
paintballjerry
paintballjerry's Avatar
I was in Wal-Mart the other day waiting on the wife. I was looking at the fishing gear and spotted some 50# test Spider Wire. I thought to my self, what the hell would you use that for in Lake Erie. It occurred to me that my tuck rails for my door surrounds were in bad shape. I bought the line and got some big needles.
Here is what I had to start with...
I started by removing all the loose thread. I threaded the needle with the Spider Wire doubling it up and tying a big knot in the other end. I started about an inch and a half back into the good stiching so that it would not unravel any futher. I followed the original hole as best as I could.
I kept going along the holes untill and stiched into the good thread another inch and a half and went back to the beginning getting the other half of the stiching.
When I got back to qwhere I strted, I tied it off really good and moved to the next bad spot. When I was finished, this it what it looked like.
The total cost for the project was about $13 dollars plus beer . It took me several hours but it was well worth it. One tip that I have is to use needle nose pliers to do the stiching, if you miss the holes in the plastice it makes it alot easier. I hope this helps others, as you can see it makes it pretty tight. Do not use monofiliment as it streches and gets brittle after being in the sun. Good luck.
<=== My Specs are there in my Profile!!!
Co-Ed Naked Jeeper Club Member #69
Originally Posted by charlescho
don;t ask here what MPG you will get with what tires etc, you will get your butt raped by the forum bullies
paintballjerry is offline
post #2 of 12 Old 07-20-2006, 12:58 AM
thesherm
thesherm's Avatar
very nice job and great right up. thanks!
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #3 of 12 Old 07-20-2006, 01:55 AM
Red_
2016 KL Cherokee
Nice
Red_ is offline
post #4 of 12 Old 07-20-2006, 07:40 AM
Rule303
I'll be doing that to mine soon, thanks.
Rule303 is offline
post #5 of 12 Old 07-20-2006, 08:01 AM
FlaJeepin
Nice repair job!
FlaJeepin is offline
post #6 of 12 Old 07-20-2006, 08:08 AM
Jeepin' Rock Cl
I ripped the zipper out of my soft top last year. Took it to a boat repair shop. $5 and 5 minutes later they had it sewn back up as good as new.
Jeepin' Rock Cl is offline
post #7 of 12 Old 07-20-2006, 08:13 AM
UnsanePyro
Very nice, I actually have to do the same thing with a couple spots on my top and was planning the same thing.
UnsanePyro is offline
post #8 of 12 Old 07-20-2006, 12:39 PM
Whobeme
2010 JK Wrangler
Looks nice too bad I can't sew.
Whobeme is offline
post #9 of 12 Old 07-20-2006, 01:21 PM
fisher836
fisher836's Avatar
Wow! that's a really good job!
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
post #10 of 12 Old 09-15-2006, 07:17 PM
addicted2quack
addicted2quack's Avatar
Thanks, it looks like that's how I'll spend part of a weekend soon!
"Fat, drunk and stupid is no way to go through life, son."
-Dean Vernon Wormer
addicted2quack is offline
post #11 of 12 Old 09-15-2006, 07:18 PM
Rocky529
Rocky529's Avatar
Looks good, you saved a lot of money fixing it yourself.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #12 of 12 Old 01-10-2008, 08:56 PM
lizard20
Great advice
lizard20 is offline
Indicator/blinker not cancelling - switch repair write up. Jonny Jeep TJ Wrangler Technical Forum 15 11-19-2015 06:52 AM
unlimited soft half top write-up 35sUnlimited TJ Wrangler Technical Forum 32 02-14-2011 08:32 AM
Windshield frame mini repair project.... davenay67 TJ Wrangler Technical Forum 2 04-21-2010 06:04 PM
How I fixed my 4 wheel drive light(mini-write-up) kaybone TJ Wrangler Technical Forum 15 01-29-2009 10:11 AM
Steering Box Frame Repair, Semi Write up ghost183 YJ Wrangler Technical Forum 11 12-23-2008 06:31 PM
