Soft top rear window zipper issue - JeepForum.com
post #1 of 17 Old 10-04-2010, 08:08 PM Thread Starter
succubus26
Does anyone have a solution for the "soft top rear window zipper" issue? I currently have a rear window that won't zip up. It's beginning to get cold again. I've always had problems with the rear window zipper on factory Jeep soft tops and aftermarket soft tops. Should I replace the zipper on my current soft top or buy a hard top?
succubus26 is offline
post #2 of 17 Old 10-04-2010, 09:25 PM
freeunit
I had the same problem which started this last spring. I ended up going to a local shop and they just put one new zipper on it, the one that you pull all the way over to the right. They put a new zipper and some how it works. I tried using wax and other lubricants on the zipper which never worked and they put a new zipper on and it works now. Not sure if I go lucky with that but worth a shot.
35" pro comp X terrain
3" Procomp
1" BL,
Sway Bar disconnects
Aussie front Locker
Uniden 510 CB
freeunit is offline
post #3 of 17 Old 10-04-2010, 09:27 PM
2jhanna
If the zipper and pull are still intact and not broke, some lube should help a lot. I use a little silicon grease wipe on both side on the zipper and then wipe off the excess. Some here use other stuff, even wax and crayons.
jhanna
denton county, tx
2jhanna is online now
post #4 of 17 Old 10-04-2010, 09:31 PM
Gobbles347
I actually just put snaps in it, only the right side is screwed up, but having snaps only on 1 side would just look stupid
Gobbles347 is offline
post #5 of 17 Old 10-04-2010, 09:59 PM
r6less
What kind of shop?
r6less is offline
post #6 of 17 Old 10-04-2010, 10:16 PM
CO_crawler
Inspect the zipper, are any of the teeth missing? Some cracks are ok too but missing ones will need to be replaced at an upolstery shop expect to pay about $80-100 for one window installed.
If the teeth are ok then you just need a new slider which I sell in my kits via paypal. 1 pull tab should do it but if its the rear you might want 2. I will send you a PM. Good Luck.
CO_Crawler
Crawlin Slow Some Where in CO
CO_crawler is offline
post #7 of 17 Old 10-10-2010, 03:11 PM
Spoonz
So how do you go about putting two zippers on the rear window? I ordered mine from jeepit.com about a month ago (is that you CO? Incredible turn around time if it was and thank you! If it's not sorry for straying!) I can get the one zipper on no problem but I can't get the double zipper going like the factory. I liked to unzip one from the left and the other from the right so they met in the top/middle then rolled it up and snapped it on nice days. Anyway to do this? Been messing with it for about an hour and can't figure it out. Any help would be awesome.
Spoonz is offline
post #8 of 17 Old 10-10-2010, 07:30 PM
Spoonz
Never mind. Took a step back, opened a beer, finished said beer, and all became clear. Is there anything beer can't do?
Spoonz is offline
post #9 of 17 Old 10-10-2010, 07:31 PM
TheStigX
I bring out a pair of pliers if the window won't zipper up.
It didn't seem that deep...
TheStigX is offline
post #10 of 17 Old 10-10-2010, 10:01 PM
bsbllyan
The top slider (when both the sliders are all the way to the left) on my rear window came off the track and I can't figure out any way to put it back on. Any ideas/tips? (besides paying an upholstery shop a bunch of money to replace it).
bsbllyan is offline
post #11 of 17 Old 10-10-2010, 11:17 PM
xlr84fun
lol, driveway articulation... thats how me and friends eat up time when we don't have money to go anywhere... lmao
2002 sport, 32" BFG AT, stock height
xlr84fun is offline
post #12 of 17 Old 10-10-2010, 11:21 PM
tcoche
looks like that guy likes his PT cruisers!
tcoche is offline
post #13 of 17 Old 10-10-2010, 11:48 PM
NCUNLIMITED
It's easy!! At the end of the zipper track there is a little metal piesce that you can pry apart and the Zipper will slide right on. Then either try to put the metal piece back on or go to an upholstery shop or a boat canvas shop and get new metal pieces and just squeeze them back on. Hopefully this makes sense to you cuz I'm kind of confusing myself. I went to a local boat canvas shop and they gave me new zipper pulls and zipper stops (the little metal pieces) for free. Just tell them you can do it yourself (you can trust me it's easy) you just need to know what you need to get to fix it.
NCUNLIMITED is offline
post #14 of 17 Old 12-17-2010, 02:28 PM
Exl2392
I tried putting a #10 zipper on mine and it keeps skipping track, never completely zips and always leaves gaps... Two upholstery shops tried Fixing it and it still will not Zip, might be easier to try in the warmer weather but when it warms up no need for windows!
Exl2392 is offline
post #15 of 17 Old 12-17-2010, 02:39 PM
timberwolf0122
I took my jeep to a tent/sail guy who put a new zip in. I now wax my zip regularly to keep it running smooth.
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
Soft top window zipper issue Ross TJ Wrangler Technical Forum 0 08-23-2010 12:29 PM
Rear Window Soft Top Zipper Help! TYrannosaurus13 TJ Wrangler Technical Forum 1 07-29-2009 02:54 PM
Soft top rear window zipper- busted J_long7 Wrangler General Discussion 2 11-03-2008 01:38 PM
soft top, rear window zipper Kachi TJ Wrangler Technical Forum 20 05-01-2007 04:28 PM
Zipper on Rear Soft Top Window Came Off Of Teeth yj_guy_007 TJ Wrangler Technical Forum 4 10-16-2006 11:08 AM
