Soft top, rear window - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Soft top, rear window
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 08-07-2007, 03:32 PM   #1
Sairys
Location: Troy Michigan, attend college at Mich Tech Univ.
Just recently traded in my 96 Cherokee for an 05 TJ. As soon as I got back up north I dropped the hard top and am now running the soft. Issue is that the rear window sags a bit past the tailgate. How have you guys fixed this to keep the rain from flooding your "storage space"?
Sairys is offline   Reply With Quote
Unread 08-07-2007, 03:58 PM   #2
Ozarkwoods
2009 JK Wrangler
Is it just the window or are your corner sails drooping also? Could be a frame issue. I have not heard of a window stretching that much that it sags. I would be looking at the soft top frame, the zipper. If all else checks out falling short of getting another rear window nothing.
Ozarkwoods is offline   Reply With Quote
Unread 08-07-2007, 03:58 PM   #3
BlueTeeJay
Have you got the metal piece that slides in along the bottom of the window and clicks in? It sounds like you may be missing something.
BlueTeeJay is offline   Reply With Quote
Unread 08-07-2007, 04:43 PM   #4
Rossta
Sounds like it. If every thing's in place, the rear window should be pretty tight, and no water should be leaking in.
Rossta is offline   Reply With Quote
Unread 08-08-2007, 10:21 AM   #5
Sairys
Hmm... just seems like the bottom of the window isn't catch on anything, so it dips a notch. I probably am missing something. ANyone got a picture of how it should look?
Unread 08-08-2007, 10:50 AM   #6
HowIRoll
When you took the hard top off did you install the small 6" long brackets on each side of the tail gate. The look like kind of like this [ .
the rear window should have a rail on the bottom that slides into to those c looking brackets and then when you shut the tailgate it holds that rail in and seals it up. I know with my TJ you have to take those brackets off when you put the hard top on and I always forget about them when I install the softtop.
You can see the bracket on the back of this jeep on the right side, above the tail light (the black bracket)
Check out my build thread: http://www.jeepforum.com/forum/showthread.php?t=503112
http://longhornfabshop.com/
HowIRoll is offline   Reply With Quote
Unread 08-08-2007, 11:53 AM   #7
fish4life
yup somethin's wrong .... my soft top is 10 years old and no sagging whatsoever. The only issue i have is scratches and stuck zippers every now and then... no sags.
fish4life is offline   Reply With Quote
Unread 08-08-2007, 11:58 AM   #8
Steelman
IX-X-XIII-XIV-XL-XLIII
Steelman's Avatar
Sounds like you are missing this ---> http://www.jeepsareus.com/Merchant2/...Code=Wrangler6
-Bob
'98 Black TJ Sport 4.0L/Auto Trans
-(O|||||||O)-
my rig: http://i9.photobucket.com/albums/a95...n/DSC06310.jpg
_____________________________________________
Originally Posted by _Trucker View Post
I would rather shoot you in the face than play a guessing game....
Originally Posted by mrblaine
Are you bipolar, passive agressive, or just unable to recognize the dichotomy of your thought processes?
Steelman is offline   Reply With Quote
Unread 08-08-2007, 01:09 PM   #9
HowIRoll
Well said. Agreed.
Unread 08-08-2007, 03:21 PM   #10
Sairys
The top was already installed, and the bracket is on there. I was wondering what it was for. I'll have to look around, maybe I just didn't see that piece when I unloaded the windows from the box. I'll call around.
Unread 08-09-2007, 01:38 PM   #11
BlueFlame
and, the plastic windows dont' usually stretch, they usually shrink. then crack...
BlueFlame is offline   Reply With Quote
Unread 08-09-2007, 01:41 PM   #12
Rossta
They crack very easy when it's cold, as I'm sure most people know. Mine's got plenty of duck tape on it. Makes my Jeep look all ghetto.
