Soft top knuckles - JeepForum.com
post #1 of 7 Old 05-03-2008, 10:25 PM Thread Starter
lilman
Soft top knuckles
I want to see how other people have repaired broken soft top knuckles. I have seen the quick disconnect kind but was wondering how others have fabbed their own. I tried a search so don't beat me up.
lilman is offline
post #2 of 7 Old 05-03-2008, 10:56 PM
happycamper
1986 XJ Cherokee
what part broke the knuckle itself or the nutsert?
Gone but not forgot. 2000 Sahara 4.0, auto, 4"rock krawler x factor long arm, 33x12.50x15 M.T. Mtz, M.T. classic lock rims,30/44 limited slip, land runner safari rack, land runner front, and rear bumpers, warn 8000i winch, cobra cb, jks 1.25" bl, brown dog 1" mm lift.AA sye, J.E. Reel drive shaft, Aussie locker, Rock Crusher front cover
happycamper is offline
post #3 of 7 Old 05-04-2008, 07:59 AM Thread Starter
lilman
I have the shell to two of the knuckles but the screw is stripped out and they are sagging pretty bad. The previous owner ran wire through the hole and twisted it.
lilman is offline
post #4 of 7 Old 05-04-2008, 10:03 AM
happycamper
1986 XJ Cherokee
what i did to mine was drill a hole all the way threw them, where the old nut was , then slid some pins threw them (i don't no what there called) they look like a smooth bolt with holes drilled in them for a cotter pin, and it worked out fine. found a pic
post #5 of 7 Old 05-04-2008, 10:34 AM Thread Starter
lilman
The hole that is welded to the roll bar is bigger than the pin though. I never really thought that it would work unless you drilled a hole in the knuckle that was the same size as that little ear on the roll bar. Thanks. I will try that.
lilman is offline
post #6 of 7 Old 05-04-2008, 09:55 PM Thread Starter
lilman
Happycamper, I appreciate this. I used the same pins that you did. i got mine from lowes and it works great. I appreciate it. I don't know why I am still playing with this Jeep cause I am about to get another one but I guess once you have one you just can't leave it alone.
lilman is offline
post #7 of 7 Old 05-04-2008, 10:10 PM
happycamper
1986 XJ Cherokee
glad it worked for you
Bestop Quick Release Bow Knuckles for your Soft Top Spagent TJ Wrangler Technical Forum 6 02-10-2010 05:48 PM
30 and 44 knuckles same? Muddeprived TJ Wrangler Technical Forum 1 09-03-2007 06:29 AM
knuckles yellow04 TJ Wrangler Technical Forum 1 04-03-2007 02:49 AM
Knuckles Anyone????? timatoe YJ Wrangler Technical Forum 4 03-25-2007 12:12 PM
wj knuckles. jipjip YJ Wrangler Technical Forum 14 04-04-2006 11:48 PM
