Soft top? full hard doors vs. half doors
| GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! |
#1 | |
Probably an easy question for those of you that know the TJ inside and out. I bought my jeep (used) with a soft top on it, but no doors. I just installed some 1/2 doors with soft uppers. There is a about a 1 inch gap at the rear portion - between the 1/2 upper and the soft top. I am guessing there are two different soft tops . . . one made for full hard doors and one made for 1/2 doors?
Am I correct? I either have to buy full doors or a new soft top?????? TIA
#2 |
Admin, Jeep in Pieces
The factory soft top fits both full hard and half hard doors w/o a problem. I have both, I know this for a fact. Is your top the factory style soft top, or is it an aftermarket one? If it is the factory top, do you have the door surrounds (fairly big, clunky plastic pieces that surround the door opening)?
You can do things the right way or the wrong way. Or you can do it MY way...which is like the wrong way, only faster. Ramsey Winches | My Gallery | www.dakuda.com |
#3 |
I don't see the large chunky plastic pieces..... The top and the soft uppers (for the doors) are OEM. I guess that is what I need.
Any pics of them? Do they bolt into place onto the roolbar or the soft top hardware? Thanks |
#4 |
Found some pics on ebay . . . I suspect that is what I need. Looks like there are different models - a folding one and non folding? Does it make a difference?
#5 |
The folding one is newer, they fit the same, but are more practical for storage.
There should be a plastic piece running along the vertiacl fron edge of your side windows, and some L shaped plastic along the top of the door frame on the soft top. DO you see those? THat def means you have the factory style top, and you need the surrounds
#6 |
There is a strip of plastic vertically and horizontally. It is hard plastic similar to that which runs along the bottom of the soft top?
Also there is a chrysler symobol etched in the soft top plastic windows, so I assume it is OEM. There is a 1-2 inch gap between the upper soft door and the soft top, so it seems that is what is needed. THanks again. |
#7 |
Just wanted to make certain we were on the same page. Sounds like it. Def try to find those used, they are pricey.
#8 |
Dakuda, do you kow if it is possible to use the later model 02-04 (or is it 03-04) tops with 97-02 (or 01). I know the tops are different, but what if you have all the hardware with it too?
#9 |
I have an 02 top on my 98. IIRC, you can go from the later years (02-04) and use the top on the earlier years, but not the other way around.
I bought my 02 top with all of the hardware, and it works perfectly fine.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
