Soft top frustration / New top advice ... - JeepForum.com
post #1 of 8 Old 05-12-2013, 10:26 AM Thread Starter
boab
Ok guys, help me pick a new soft top, its taken me over an hour already to try and get this wrecthed smittybilt soft top on, in 45F weather. Way too much frustration with the back window zipper!!!!!!
wants
(a) easy to put the darned thing back on
(b) being able to fold the front part back for "sunroof" mode, when the weather is more iffy
also any advice on how to get this darned back window in would be so gratefully received. I'm thinking the smittybilt top was the cheapest for a reason... so frustrated!!!!
boab is offline
post #2 of 8 Old 05-12-2013, 10:55 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
How do you expect to get a top on when its 45 degrees out?
It's pretty crappy out there today around here too.
Wheelin98TJ is offline
post #3 of 8 Old 05-12-2013, 10:57 AM
gloksrule
I also have a smittybuilt, but it sounds way too cold where ur at, it can't stretch at that temp,I think the instructions say install when it's +75', otherwise u risk breaking the zippers,, good luck
gloksrule is offline
post #4 of 8 Old 05-12-2013, 04:34 PM
06philaTJ
It was a pain for me to install my smittybuilt top and it was 70 and sunny out when I did it. It's a really tight fit for the top compared to OEM, or at least the OEM 2006 top I was using originally.
I'd suggest starting your Jeep, turning on the heat full blast/hottest setting, and aim the vents at the roof of the top. It'll help loosen the top up enough to get the windows zipped up. You'll want to have the doors closed, the front uppers install, and the roof/rear sail panels latched down (clamp down the header clips last though, just have the latches in the hole).
It should only take a few minutes for the heat to noticeably loosen the top so you will barely use any gas at all letting it idle. I do this sometimes when re-installing a soft top at night when its cool so I don't have to spend 20 minutes fighting with zippers.
06philaTJ is offline
post #5 of 8 Old 05-12-2013, 04:37 PM
2jhanna
I know on my OEM top a little lube on the zippers help, hot or cold.
jhanna
denton county, tx
2jhanna is offline
post #6 of 8 Old 05-13-2013, 05:49 AM
bdub1285
I just got the Softoppper frameless soft top. I would recommend checking it out.
2001 Jeep Wrangler Sport, 4.5" lift, Front/Rear ARB Air Lockers, Dana 30/Dana 44 axles with alloy shafts, 4.56 gears, Weld in Roll Cage, 35x12.50 Cooper Discoverer Tires
bdub1285 is offline
post #7 of 8 Old 05-13-2013, 09:14 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You are correct!
Install the front and pull down really hard on the rear frame and it will go on in any temps.
TheBoogieman is offline
post #8 of 8 Old 05-13-2013, 10:27 AM
jimwww
jimwww's Avatar
70f to get a top on. Find a heated garage. I just bought a Frameless NX Bestop and at 68f I could not put the side windows on.
1999 Jeep GC Limited ( WJ ) V8
jimwww is offline
