Soft top compatibility - JeepForum.com
post #1 of 5 Old 06-04-2005, 08:33 AM Thread Starter
debblitch
Am looking for a complete soft top set-up, top and all hardware for my '04 Wrangler. While looking on E-Bay, I see lots of '97-05 sets for sale. Are they all compatible.....i.e., can I install an '02 on my '04?
debblitch is offline
post #2 of 5 Old 06-04-2005, 08:40 AM
Alec
You may do that but you must aquire the complete set (hardware, windows, and top)
Also, you will be needing the door surrounds ( a complex piece of plastic shaped like a "7")
Those are necessary to fill the gap between the soft top and the doors (full or half doors)
If you need the COMPLETE kit .... go right ahead.
Windshield, doors , tub, and overall dimensions have not changed on the tj since 97; you will be fine if you get the complete set
97 Green Sahara -
Powertrain envy sufferer - Softop tinkerer
Alec is offline
post #3 of 5 Old 06-04-2005, 09:19 AM
Jim Shanks
Jim Shanks's Avatar
The only catch I have heard of for going the direction you are is they supposedly made the holes in the windshield frame smaller. Going newer top with frame to an older Jeep is not a problem, I do know that one for sure.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #4 of 5 Old 06-04-2005, 01:17 PM
volleygirlamy
I have a bestop supertop for sale in the "for sale" section if you are interested in it. Its black denim with regular windows not tinted, w/o the upper doors.
volleygirlamy is offline
post #5 of 5 Old 06-04-2005, 01:22 PM
logixrat
I also have an 04 model w/ factory hard top and looking for a soft top. I have heard that either 02 or 03+ models changed slightly. Something about the angle of the windshields being ever so slightly different. The end result is that you have to fiddle with an older top to get it to fit right on the 04 model.
Again, these are just odds & ends I have heard. I wish I could get a definitive answer on the matter.
In regards to the Supertop, they are good deal. Things I don't like are you have to replace the entire unit (fabric & frame) as they don't sell a top only. And the frame work is different so a factory top won't work with it. That only matters if you plan on keeping the Jeep forever, which I do.
Lowrider Donnie.....Donnie, Lowrider
logixrat is offline
Soft Top Compatibility tangofox007 TJ Wrangler Technical Forum 13 03-01-2010 02:53 PM
Soft top compatibility ltdanyj YJ Wrangler Technical Forum 8 11-17-2009 03:04 PM
Soft top compatibility. Deadhorse TJ Wrangler Technical Forum 3 10-22-2009 07:41 AM
LJ Soft top compatibility metomwhou TJ Wrangler Technical Forum 1 05-20-2009 06:44 PM
Soft Top Compatibility Doogie1022 TJ Wrangler Technical Forum 1 04-16-2009 07:39 PM
