soft brakes and brake lights not working - JeepForum.com
post #1 of 6 Old 01-09-2014, 03:51 PM Thread Starter
cwig12
1983 CJ7
All of the sudden the brakes on my dad's 98 tj went soft when turned on and driving. Checked fluid levels and they are full, checked the vacuum line, clear of debris. When the car is off the brakes are stiff. Also the brake lights won't work either. Any ideas? It's a manual transmission if that matters.
Creative-X - Web Design and 3D Printing
My portfolio:
cwig12 is offline
post #2 of 6 Old 01-09-2014, 05:09 PM
JFM626
JFM626's Avatar
I can't see the two being related, but check you fuses first for the no brake light problem.
For the soft pedal issue, (without loss of brake fluid) I'd pull the wheels and check for loose and broken or missing parts. I have seen where the brake disc pad has fallen out, (high mileage on pads and rusty)
How can you trust an atom, they make up everything
JFM626 is offline
post #3 of 6 Old 01-09-2014, 06:18 PM Thread Starter
cwig12
1983 CJ7
Fuses appear to be fine, checked the brake pedal switch that pushes in and releases against it. That seems to be fine. Ran the hazard lights and everything works, flipped the other switches and those work. Reseated some connections and still nothing.
My portfolio:
cwig12 is offline
post #4 of 6 Old 01-09-2014, 07:04 PM
JFM626
JFM626's Avatar
Originally Posted by cwig12 View Post
Fuses appear to be fine.
With the new style fuses, a visual check quite often is not enough. Use a multi mrter set to ohms to check for continuity. You don't need to remove the fuse to do this. As well as checking the fuses under the dash, check the ones under the hood as well.
JFM626 is offline
post #5 of 6 Old 01-09-2014, 08:14 PM
Karottop
When the jeep is running does and you press the pedal, does it slowly creep to the floor? Can you pump it to regain pressure? Check the floor of the jeep on the drivers side for wetness. If the master cylinder is leaking it will usually leak on the inside, and it might not be visible right away in the reservoir.
Karottop is offline
post #6 of 6 Old 01-09-2014, 08:21 PM Thread Starter
cwig12
1983 CJ7
Ill have to check, unfortunately it's all wet due to melting snow. Thanks.
My portfolio:
cwig12 is offline
