So you want a Tummy Tuck... - Page 69 - JeepForum.com
 1Likes
post #1021 of 1106 Old 03-25-2013, 06:26 PM
Ben
Originally Posted by Ironhead View Post
Yep, uhc .250 aluminum
I spoke with UCF about it, their warranty covers their defects, not my choice of obstacles, I can't blame them for that.
Matt did offer to help me with the cost of a 3/8", but I'm just gonna run this until it doesn't work anymore.
He said he's only ever had 1 other 1/4" AL plate get bent, so it must not be common.
It's got a little more clearance for next time I guess.
Ben is offline
post #1022 of 1106 Old 03-25-2013, 06:36 PM
Ironhead
but was it supposed to have two sets of mounting holes?
even better, are there two aluminum braces going across the top side of the skid?
i'd think that would add more strength but rob clearances
Ironhead is online now
post #1023 of 1106 Old 03-25-2013, 06:53 PM
Ben
I didn't ask about the holes - maybe that's a 4 banger thing.
Only 1 crossmember.
Ben is offline
post #1024 of 1106 Old 03-25-2013, 06:59 PM
jeepbro's
This is a very good read, and I read over most of the first page but did not read all 68 pages, but am looking at making a decision soon and would like to get some opinions on some parts I'm looking at and what all I need.
First off about my jeep. I have a 1.25" jks body lift and 2" springs but after some measurements compared to my stock TJ, my jeep is really at 1.5" of suspension lift.
So, I need an SYE because recently an unknown bad u-joint caused a drive shaft and subsequently a transfer case output shaft failure so I figure its the same labor to replace with stock or upgrade to an SYE, and if I'm doing a SYE why not finally do a tummy tuck.
So first question is whether to get regular SYE or super short style? I understand some of the benefits but i found the rugged ridge regular SYE for 150, and that price is a lot easier on the pocket over the 260 at least for every super short SYE. So is it worth the money to go super short for any lift/tummy tuck height? I was thinking since I'm doing some kind of SYE I may go up almost another inch in suspension since my fenders are all stock and are really close to the tires right now anyways so my height would be higher than I indicated earlier. Next, does anyone have any experience with the Teraflex Extreme short shaft SYE kit? its a few bucks less than JB super short kit and its actually in stock right now, so is it any good if I went super short style?
Next question, I'm debating what skid to get, I'm thinking UCF skids but cant decide which one based on a few factors. I know I dont have the money to go aluminum so I know it will be steel. But is there any chance that with an SYE and a skid near stock height I wont need adjustable upper control arms or will I no matter what need adjustable upper rear control arms. I was thinking if I didnt move the skid up too much I might not need the uppers, but if I need them no matter what then I might as well go with the skid that gives the most clearance.
Also one more question, I see on their website the low profile transfer case mount, what is that needed for? will I need it or is it just optional?
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #1025 of 1106 Old 03-26-2013, 06:30 AM
geiman
If you install an SYE, you need to change the pinion angle appropriately:
http://www.4xshaft.com/images/2joint_angle.gif
http://www.4xshaft.com/images/cv_angle.gif
It will be easiest to do so with adjustable control arms.
As for SSYE vs SYE, it never hurts to have a longer driveshaft in this situation. The SSYE will be more expensive in the long run, but it can be very beneficial. But then again depending on your lift height and everything else an SSYE might not be necessary.
geiman is offline
post #1026 of 1106 Old 03-26-2013, 07:50 AM
rda616
By the time you replace the seal that comes with the rugged ridge sye you could have bought a jb conversion sye. Even the standard jb is shorter then the rr sye. if you go ssye you will need a speedo healer to correct the speedometer.
The low pro mount is for improved driveshaft angles and clearance above the transmission and transfer case.
rda616 is offline
post #1027 of 1106 Old 03-26-2013, 08:12 AM
rda616
I just picked up a Barnes 1/4" steel flat skid for $140 shipped. Going to be interesting to see how it will all work with my new 44re. Also picked up a clock ring for the transfer case.
Got to see if the teraflex seal spacer will work with the overdrive transmission and clock ring. Any other longer seal suggestions would be great.
rda616 is offline
post #1028 of 1106 Old 03-26-2013, 11:17 AM
jeepbro's
I just looked them up, seems like a really good price, anyone have any experience with them? that might be a good solution for me to save a few bucks and just have to drill out some hols for the t-case mount. Also, would I need the low pro transfer case mount? I understand that it lowers the transfer case closer to the skid but is this really needed or is it optional depending on lift height. I may get the Barnes 0" drop skid and be at a total suspension lift height of 2-2.5", and trying to figure out if I would need the low pro transfer case mount if I go with the teraflex extreme short shaft SYE.
post #1029 of 1106 Old 03-26-2013, 11:44 AM
rda616
At that point I would fab my own mount. You may need to clock the case to clear the skid , or bang the heck out of the tub with a bfh, or both! I'm going to pick my skid up in about ten minutes since it was just delivered. I'll try to do some test fitting tomorrow and let you know. Although you need to take into consideration I have a v8 and 44re, so mounting points and clearance may not be the same for your setup.
rda616 is offline
post #1030 of 1106 Old 03-27-2013, 12:09 PM
rbkelley89
ive got the barnes flat belly skid. get some good drill bits and pilot the holes 1/4" is thick!! ive got some vibrations because i wasnt able to get an aftermarket tranny mount i have the unfortunate luck of the 30rh. i plan on adding a few washers to try and lower it im not sure if the vibes are from contact or the new bd motor mounts that i installed at the same time but skids good i also plan on counter sinking the holes that mount to the frame. not sure what to do about the motor mount though id love to have the lowpro mount.
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline
post #1031 of 1106 Old 03-27-2013, 01:08 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
How much suspension lift do you have? Your lower control arms are steep! Did you have to modify the floor or clock the 231 to run the flat skid?
Mail crawling.
MisfitSeven is offline
post #1032 of 1106 Old 03-27-2013, 01:40 PM
rbkelley89
its rc 4" springs but rotating the pinion so high it is now uneven with the front. the uppers are even worse there at the end of the thread on the currie adjustables. didnt modify the floor at all wish i hit it with a mallet a few times. i will be adding most likely two sets of washers to try and bring the pinion down a bit get rid of the vibes and counter sink the holes to finish it up. The stock tranny mount is why the pinion is so high
post #1033 of 1106 Old 03-27-2013, 02:01 PM
Imped
Imped's Avatar
The stock tranny mount + such tall springs on a SWB TJ is the problem. Very high pinion and control arm angles.
OlllllllO
IndyORV
Imped is offline
post #1034 of 1106 Old 03-27-2013, 03:27 PM
rubicon17
imped do you think id benefit at all from a lowpro mount? just put on the no bl skid and have 4" springs as well. pinion doesnt seem that bad but i dont really know whats good so? fan blade is close to the shroud but doesnt make contact at all. any mods to use it with the 42rle? i seen that pic the one guy said he modded the stock mount but i dont know what im looking at in the pic. matt said the no bl raises everything 1.25".
100% HAWAIIAN KONA & JAMAICAN BLUE MOUNTAIN COFFEE FOR SALE PM ME
rubicon17 is offline
post #1035 of 1106 Old 03-27-2013, 05:52 PM
rbkelley89
agreed. My jeep is no longer leval either so i am thinking about getting the 3" metal cloak dual rate springs and would love to cut 3/4" out of the stock mount, im kinda waiting for ucf or savvy to make a mount for the 30 rh but i dnt think i should hold my breath if i could i would go with the lopro!!
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 02:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 05:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 02:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 07:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 06:31 AM
