So you want a Tummy Tuck... - Page 67 - JeepForum.com
 1Likes
post #991 of 1106 Old 03-23-2013, 08:58 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by chris86vw
Finally got to doing mine, bought all the materials last summer but then I was traveling for work constantly and moving at the same time. Decided it needed to get done so got to it today. I still need to make a new skid, have a piece of aluminum I picked up last summer just need to drill and get it in place. Also need to paint it and rebuild the exhaust which I wanted to anyway. Unfortunately on the test drive I pulled the front shaft a part, apparently it is no longer long enough so I need to sort that out. When I did my super short SYE late last summer I built the shaft based on the tuck (know I would have no time to take it off road) so that is now perfect length.
I forgot to take pics of it in place once it was all done, phones out in the shop and I need to get home to walk the pups so I'll post up those later.
Why is the plate offset on your new crossmember?
Mail crawling.
MisfitSeven is offline
post #992 of 1106 Old 03-23-2013, 09:28 PM
chris86vw
Rear ds is fine, already built from an xj front shaft last summer (same with the one before the ss sye)
The front is the current problem it pulled apart on the test drive. I didn't put it back together since I needed to get home but it looked like it was only engaged about half an inch when I held the two halves in place. Will pull it tomorrow when I go back in to measure.
Stock xj front shaft is shorter than a stock tj shaft from what I have read, only junkyard I know of is closed tomorrow so can't check.
My guess is that my tc is slightly further back then most after the swap despite trying build it around a stock tc location, oh well. Guess i'll decide on a new suspension setup and leave it 2wd until then so I can build something custom.
98TJ 4bt, 15GSW TDI, 12JSW TDI, 06 A3 2.0t GTX3071R, 00 Audi TTQ, 80 rabbit pickup, 02 LR Freelander
chris86vw is offline
post #993 of 1106 Old 03-23-2013, 09:42 PM
MisfitSeven
MAiL Crawler.
What I meant was that your mount isn't centered between the driver and passenger side frame rails, not front to back. Why?
Mail crawling.
post #994 of 1106 Old 03-23-2013, 10:09 PM
chris86vw
I was replying to previous comments about using an xj front shaft.
The mounting points on the trans are not centered between the frame rails stock. The Cummins to gm bellhousing adapter clocks the trans slightly to the driverside which put my shifter into the side of the center console. Prior to the tt I slotted the stock mount so I could move the trans left to right to get into all the gears, so it is probably slightly more to the passenger side than most but still no more then a 1/4 inch or so.
post #995 of 1106 Old 03-24-2013, 09:32 AM
chris86vw
some more pics from when I came into the shop this morning:
cross brace installed, ignore the few mig welds you can see, was using the shop one which is ancient and has been acting up, after some frustration I got unlazy and got mine out of the car the rest are much nicer, you just can't see them. The brace itself is tig welded but the brackets to the frame are mig:
And the clearance of the front output to the brace, super close its just barely touching right now with the axles pulled out and at an angle well beyond that of what it would see at full droop. I had no rubbing with the jeep in the air and axle all the way down so its future proof to the point of any lift I would do, plus a hp30 is coming soon.
post #996 of 1106 Old 03-24-2013, 02:25 PM
MisfitSeven
MAiL Crawler.
Very good. I wasn't aware of your unique setup. It actually looks just like my crossmember.
When I swapped my 4.0L in place of the 2.5L the motor mounts moved right before burning them in place. This placed my trans crossmember mount a few inches off of center. So I built my own using tabs, tube, and half of the stock mount. It came out off center just like yours, which lines up perfectly with the offset of my 8.8.
So, are you planning on swapping out your rear axle? I think an 8.8 is right up your alley.
Mail crawling.
post #997 of 1106 Old 03-24-2013, 10:05 PM
ddz1952
I waited 6 weeks one excuse after another, finally gave up.
ddz1952 is offline
post #998 of 1106 Old 03-25-2013, 06:00 AM
chris86vw
Yup 8.8 sometime sooner than later. I hadn't done it since I was deciding on gearing. Now that I'm settled on 3.07 I'll get to doing it. Well now I have to decide if I want to 4link or not...
Unfortunately all the 8.8s with that gearing are drum I believe from my research
post #999 of 1106 Old 03-25-2013, 06:18 AM
Ironhead
wait, you want 3.07 gears?
Ironhead is offline
post #1000 of 1106 Old 03-25-2013, 07:06 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
sounds about right for a Cummins 4BT swap, depending on tire size.
redline is like 3000rpms, and you probably want it to run around 1500-2000 rpm on the highway.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #1001 of 1106 Old 03-25-2013, 07:10 AM
Ironhead
that is what i wanted to know. just seemed odd, but i have no experience with the cummins
Ironhead is offline
post #1002 of 1106 Old 03-25-2013, 10:33 AM
chris86vw
hey now I have the 32000 rpm spring in it!!
But yes 3.07s put me at about 1700 or so doing 70mph on the highway with 31s or 33s, forget my last calculations which is pretty much ideal. Right now with the 4.10s and the 31s doing 70 down the highway I am over 2200 rpm I think (no tach and forget what it worked out to) which is sort of fine but out of its efficiency and doesn't give you any room to speed up if needed. 3.07s it pulls like a freight train to 90+ I drove it up from GA to WV end of last summer with the 4.10s and it was miserable.
with the 4.10s and the torque though my twisty hilly drive to work though I rarely need to leave 5th gear I can go from 20-60+ never shifting, but I"m always looking for 8th gear when it is straight.
Anyway my new trans brace is making fitting my exhaust quite fun, decided to give up on reconfiguring the existing pieces and just starting from scratch again. The downpipe was stainless and the rest was mild which I wanted to redo anyway as well as get rid of the muffler. So she sits while it snows unable to be driven.
The few rips around the area with no exhaust on it the trans feels great, much more solid, no more hitting stuff in the cup holders or jamming my finger on the parking brake if I put it in reverse before releasing the brake. Have not warmed it up fully but I suspect cabin vibrations will be up a bit, however it will be worth it with the way the trans feels now.
post #1003 of 1106 Old 03-25-2013, 11:08 AM
theremikegoes
Anyone have a good online source for aluminum sheet for the skid? my local steel supplier cant or wont bother to get anything more than really thin stuff.
The garage is a happy place...
theremikegoes is offline
post #1004 of 1106 Old 03-25-2013, 11:55 AM
chris86vw
Metal supermarkets, not sure how far any of their pnw stores are to you, but you can order online and pickup in store if they aren't too far.
post #1005 of 1106 Old 03-25-2013, 12:10 PM
Ben
I'm not sold on aluminum for the center skid.
My first real trip out in some rocks with my 1/4" UCF skid, and it's dented in pretty bad.
Not sure if I want to replace it or what, kinda bummed with the cost/performance ratio on the part.
Ben is offline
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 01:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 04:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 01:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 06:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
