So you want a Tummy Tuck... - Page 61 - JeepForum.com
 1Likes
post #901 of 1106 Old 12-10-2012, 09:38 AM
emev0l
Originally Posted by rbkelley89 View Post
just took measurements to order rear drive shaft. 22" does this sound good. took measurements from flange to flange at 9' o'clock position
Yes, 22 sounds good, I think mine is 21
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #902 of 1106 Old 12-16-2012, 09:19 AM
Ironhead
am I the only one that had fan issues after installing a TT?
it just barely rubbed, but still, no one else?
Luckily i have done a few bl and mml, so i had all the drop brackets necessary to drop my radiator 1"
maybe i missed it in this thread, maybe i did something wrong, or maybe it's true..every jeep is different
Ironhead is offline
post #903 of 1106 Old 12-16-2012, 09:22 AM
biffgnar
biffgnar's Avatar
Sure, but five minutes with a dremel to slot the bolt holes in the shroud and you can adjust it as necessary.
Romney in 2020!
biffgnar is offline
post #904 of 1106 Old 01-17-2013, 03:16 PM
2005rubi
I removed the stock spacers on the stock skid for now with now issues but since this thread has been going on for a while, I was wondering if anyone with a LJ Rubicon had to do the BL, MML and SYE with the UnderCover Fab skid since it looks like this particular vehicle has a SYE in the rear and a DC in the front?? I tried reading through all 61 pages but was hoping to see if anyone is LJ Rubicon specific. Thanks! Your help is greatly appreciated.
2005 Jeep Wrangler Unlimited Rubicon, 3.5" Fabtech/Rubicon Express suspention lift, 33" TOYO Open Country M/T's, S&B Cold Air Intake, custom exhaust, Rigid Industires Duallys, Poison Spyder hood louver and steering box skid, XRC winch, Currie Anti-Rock and Curectlynk steering kit, PowerStop brakes.
2005rubi is offline
post #905 of 1106 Old 01-17-2013, 03:29 PM
kylekae
I know u don't need a sye cause the Rubicon have a fixed yoke.
kylekae is offline
post #906 of 1106 Old 01-17-2013, 04:40 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by kylekae View Post
I know u don't need a sye cause the Rubicon have a fixed flange.
fixed it for you.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #907 of 1106 Old 01-17-2013, 07:24 PM
kylekae
fixed it for you.
What haha
kylekae is offline
post #908 of 1106 Old 01-17-2013, 08:15 PM
Unlimited04
What haha
here's the output of a TJ/LJ Rubicon NV241OR:
the front of the t-case is an example of a "fixed yoke" output. the rear t-case output is a "flange", not a "yoke". however, there is a part called the "flange yoke", which is part of the rear driveshaft itself, and bolts to the "flange".
More info here:
http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
Useful Write-Ups:
Funny:
post #909 of 1106 Old 01-17-2013, 08:33 PM
clg82
I have a quick question about tummy tucks and the FRONT pinion angle. I know it's not as important as the rear but after installing my savvy modular with crossmember it seems the front is more extreme than I was expecting. Any suggestions?
clg82 is offline
post #910 of 1106 Old 01-17-2013, 08:35 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Time to start looking for a high pinion front axle.
Mail crawling.
MisfitSeven is offline
post #911 of 1106 Old 01-17-2013, 08:49 PM
clg82
I can't just adjust it with the control arms?
clg82 is offline
post #912 of 1106 Old 01-17-2013, 09:05 PM
MisfitSeven
MAiL Crawler.
You really can only adjust so far before it starts affecting your steering.
Mail crawling.
post #913 of 1106 Old 01-17-2013, 09:10 PM
Unlimited04
you have to make a compromise between pinion angle and caster.
x2...
The only other option is to cut the inner C's off and change the caster/pinion angle separation.
Useful Write-Ups:
Funny:
post #914 of 1106 Old 01-17-2013, 09:22 PM
clg82
x2...
Hmm and the difference between pinion angle and caster is…
clg82 is offline
post #915 of 1106 Old 01-17-2013, 09:32 PM
rchase559
Hmm if only there was a way to search for an answer to this...
rchase559 is offline
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 01:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 04:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 01:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 06:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
