So you want a Tummy Tuck... - Page 57 - JeepForum.com
 1Likes
post #841 of 1106 Old 09-29-2012, 09:57 PM
2003X
Here are some different views of the clearance on the skid plate. One of the best mods you can do.
My Build
2003X is offline
post #842 of 1106 Old 09-30-2012, 06:44 AM
saxart
2000X-
Those are great pictures of that skid. Thanks for posting them. What is that "spacer" between your skid and the frame?
All-
Does anyone have a picture of UCF's "No Body Lift" skid installed?
I intend to live forever. So far, so good.
'99 Wrangler Sport: 2.5" Old Man Emo lift and shocks, adjustable trackbars, Quick-Disko sway links, rollin on 31" BFG A/Ts
saxart is offline
post #843 of 1106 Old 09-30-2012, 07:54 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
That spacer is part of the Rough Country long arm setup he has. It connects the LCA mounts together.
How much clearance was gained at the skid from stock with that setup?
Mail crawling.
MisfitSeven is offline
post #844 of 1106 Old 09-30-2012, 09:01 AM
GMBNT42
Looks like he has UCF's "original" clearance skid.......plus the spacer.......he probably gained 2" clearance over the stock shovel skid.
I have the UCF "Ultra clearance skid" and no spacer.....so I have about 3.5-4" gain in clearance over stock skid.
GMBNT42 is offline
post #845 of 1106 Old 09-30-2012, 09:29 AM
2003X
Originally Posted by saxart View Post
2000X-
All-
Thank you -
The skid plate is the Original Extra-Clearance Carbon Steel 3/16" Skid Plate. The spacer is part of my long arm set up. It is only 1/2" thick. I probably gained about 3" over stock.
My Build
2003X is offline
post #846 of 1106 Old 09-30-2012, 09:52 AM
2003X
Here is a pic from a distance. The clearance is incredible.
My Build
2003X is offline
post #847 of 1106 Old 09-30-2012, 11:29 PM
97wrangler-242
Here's a 1/4" (stock shovel is 1/8") ultra high clearance ucf and some comparison pics. Matt's oil pan skid is hanging on the wall waiting to be installed. Has 2 mounting points to take advantage of a mml for 1" additional skid clearance. Plan on picking up his 1" raised gas tank skid for a nice set with more clearance than the next guy . Did a rough country bl, jks mml, novak cable shifter, and all the works from currie and Adams driveshafts for a sye which was NEEDED for just the skid on stock springs, no spacers. Learned the hard way, spend the extra 40$ to get a jb conversions sye. They have the shortest yoke of all sye's with a double sprung seal that won't leak like the joke of a sye rugged ridge sells. The output seal has soaked my skid in tranny fluid. Lube for sliding over rocks? Haha
97wrangler-242 is offline
post #848 of 1106 Old 10-01-2012, 07:06 AM
GMBNT42
Yep, love my UCF system, I have the Ultra clearance skid with the engine skid and 1" gas tank tuck skid. Fantastic products.
GMBNT42 is offline
post #849 of 1106 Old 10-02-2012, 11:28 AM
TroubleNEO
2003X, looks good, I had almost the same setup as you, but I sat on my tummy tuck skids for months until I could get around to welding on the control arm brackets and getting rid of the stupid bolt on Rough Country bracket.
I would have not taken the corner out of the skid to fit around the bracket, but that's just me. There are many things inherently wrong with that bracket like it acting as a TCase drop, and only securing the skid with 4 of the 6 intended bolts. Even worse, is now the rear section of that skid is compromise strength wise. There is a reason the skids are corner boxed like they are, it is what enabled them to take hits without deforming. I guarantee if you hit the back end of the skid on something its going to bend upwards, ask me how I know.
Anyways, here is a side picture of the one I just finished. I definitely have room for a higher clearance skid, but I wasn't going to argue with a gently used Jeep Medic skid for 1/4 of the price they are new.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #850 of 1106 Old 10-02-2012, 11:50 AM
undercoverfab
Vendor
undercoverfab's Avatar
Nice job on the control arm bracket install! Now you need the Ultra High-Clearance skid.
Matt Walton
(334) 446-3821
Use the coupon code "jeepforum.com" to save 10% today!
Check us out on
undercoverfab is offline
post #851 of 1106 Old 10-02-2012, 12:59 PM
GMBNT42
Originally Posted by 2003X View Post
Thank you -
If its the orignal skid, plus the half inch spacer means you gained about 2". THe original skid plate is 2.5" over stock roughly in gained clearance without the spacer.
GMBNT42 is offline
post #852 of 1106 Old 10-02-2012, 08:21 PM
DevilDogDoc
Jeep medic 1/4 inch I wish I had measured before I dropped the old skid but stock + TC drop = the suck. A bit higher and a lot stronger. Only thing was it was off of a late model TJ so I had to drill and set new nutserts in the right spots.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #853 of 1106 Old 10-02-2012, 08:58 PM
DevilDogDoc
Same pic.
post #854 of 1106 Old 10-03-2012, 11:47 PM
danielbuck
1946 CJ2
And something you didn't mention. SMOOTH! The factory transfer case skid (on my manual transmission anyway) is horrible at grabbing on to rocks and things and holding on tight. With those ribs that are bent into it, it's not a slider at all, it's just protection, that's it. Even if it's no higher up than stock, smoother is better
danielbuck is offline
post #855 of 1106 Old 10-07-2012, 03:55 PM
Xjman1
So I installed the UFC UHC skid on my '01. Even with a 1.25" BL and 1" MM lift and stock MM's the fan still hit the lower half of the shroud. I changed out the mounts and installed Brown Dog Mounts and the fan now clears by about 1/4". Any one else run into this issue? I am worried about when the drive train flexes it may hit.
My options I see so far would be to lower the shroud, trim the shroud or place a small spacer under the 1" MM lift to gain me another 1/4" or so.
It seems that on the '01 with the stock transmission mount and UHC skid the transmission may now be higher than the engine.
Xjman1 is offline
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 01:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 04:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 01:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 06:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
