So you want a Tummy Tuck... - Page 50 - JeepForum.com
 1Likes
post #736 of 1106 Old 06-12-2012, 08:19 AM
Ironhead
any chance that I wont have driveline vibes without a new DS? 2" of lift and its a rubi, so no yolk to eliminate. Adj rear uppers. about to install the UHC skid with a lopro
Ironhead is online now
post #737 of 1106 Old 06-12-2012, 08:27 AM
Imped
Imped's Avatar
Not a very good chance, but it's a function of which skid you're installing.
OlllllllO
IndyORV
Imped is offline
post #738 of 1106 Old 06-12-2012, 10:19 AM
polo196
Well, located source of DW. Boy do i feel stupid. Forgot to tighten front LCA where oil pan skid attaches. Its the little things that matter.
I definetly would go with cable shifter and wish i had it yesterday.
Imped is that right on the two degree difference or did I get some bum scoop.
Rubiconchris i did not need the lopro mount but it might of been nice to have.
Wow, I'm a member. Thats not the word I'm normally called.
Yellow Jeep Club Member #196
polo196 is offline
post #739 of 1106 Old 06-12-2012, 10:22 AM
Imped
Imped's Avatar
You want the pinion inline with the drive shaft, such that the u joint is seeing no angle. The -2 degrees statement is accounting for axle wrap when on the gas. If you've got some deflection from the bushings in your control arms, you'll have a little axle wrap. If you're running rod ends or JJ's at all ends, you'll have virtually none.
In other words, you're fine where it's at.
OlllllllO
IndyORV
Imped is offline
post #740 of 1106 Old 06-12-2012, 07:30 PM
RubiconChris
Is there a differance in the rear Tatton driveshaft for my Rubicon and the Tom Woods shaft besides the price. I`ve read good reviews on Tatton shafts both come with spicer 1330`s. This Belly up project is costing a bundle and I need to save anywhere I can. Thanks
2015 Jeep Wrangler Willy`s Edition with 2.5 inch Tera Flex BB with quick disco`s. Much more to come!
RubiconChris is offline
post #741 of 1106 Old 06-12-2012, 07:36 PM
undercoverfab
Vendor
undercoverfab's Avatar
Originally Posted by polo196 View Post
Aww jeez, just spent 8 hours trying to get my ucf skid on. First problem was i had to remove the transfer case shift linkage i put on with the lift. I got that off and jacked the skid up and the TC linkage was in a bind. Tried to call ucf but got voicemail and no call back So i pulled it off and welded a tab to the bottom, then drilled a hole lowering the pivot point. This worked out well and the TC shifts like its suppose to. I modded my skid row oil skid and bolted it up to the ucf. Then adjusted rear uppers and lowers. I started with a Ds angle of 18, no vibes. It was now 25. So i adjusted it down to 22 at ds and 20 at pinion. Two degrees difference is what i had read so i thought i would be ok. But now i have vibes and terrrible Dw. I parked it and started crackin beers. BTW I did nothing to the exhaust yet. It is snug. Also the steering feels kinda strange when I turn to the left.
Sorry I missed your call. I've been on vacation for the last week.
I tried to call you back today and got your VM. Please call me if I can help.
Matt Walton
(334) 446-3821
Use the coupon code "jeepforum.com" to save 10% today!
Check us out on
undercoverfab is offline
post #742 of 1106 Old 06-12-2012, 07:45 PM
clg82
is a SS sye needed for your undercover system like the savvy one requires?
clg82 is offline
post #743 of 1106 Old 06-12-2012, 07:49 PM
undercoverfab
Vendor
The UHC (Ultra High-Clearance) skid will require a SYE of some kind unless it's installed with no suspension lift. You may need a Super Short or Mega Short model if you try to install it with over 3" of SL. Your specific situation will dictate that.
Thanks,
Matt Walton
(334) 446-3821
Check us out on
post #744 of 1106 Old 06-12-2012, 07:59 PM
clg82
Thanks,
thanks for the quick reply.
clg82 is offline
post #745 of 1106 Old 06-12-2012, 10:01 PM
polo196
No problem, everyone needs family time. Today I had to work overtime so not much of a chance to work on it. I tightened up the front LCA, it really wasn't that loose. I drove it to the store and it still tried to DW on me. The exhaust is making an awful racket. Taking it in tomorrow to get that fixed.
Gonna trade out my crappy ProComp Xterrains for the new MTR's I have.
Thinking about trying to lower the DS angle some more, to get closer to the 18 degrees I had with no vibes.
I have come to the conclusion, after reading multiple threads on this, I actually know a lot less than I thought I did.
polo196 is offline
post #746 of 1106 Old 06-13-2012, 06:05 AM
TroubleNEO
The good thing about TW is that Tom stands behind his product. Unless you turn the thing into a banana on the trail, he'll figure something out to help you. Usually it's "send it back and we'll take care of it", and it is not at all uncommon for him to split the cost of repair when the situation is completely the consumers fault.
I have never dealt with Tatton, however I would venture a guess there is a very strong difference in customer service. There are only a handful of companies out there that have seen the success that TW has and to this day the owner himself still answers the phone. Give them a call any given day of the week M-F and you're likely to have Tom answer and phone. What you'll find during your conversation with him is a person who actually cares about each and every customer he has. People are beating down that mans door for driveshafts and he has plenty of business, yet he'll spend twenty minutes on the phone with you answering all your questions, and even just having general conversation.
Not because he wants your money or wants to make a sale, but because he cares about you, and he doesn't even know you.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #747 of 1106 Old 06-13-2012, 06:14 AM
BioTex
1979 CJ7
Just my opinion on Tatton's!
I have ordered from them twice now. When I call, I get Curtis himself on the phone, and so I beleve their customer service is the same as TW. Shipping is fast, and like you said, the products appear the same. Warranty appears the same. I have never heard bad from either place, so why not save some money where possible.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #748 of 1106 Old 06-13-2012, 06:18 AM
Imped
Imped's Avatar
There are other shops out there that have the same (and some better) rep as TW. Tattons is one of them.
OlllllllO
IndyORV
Imped is offline
post #749 of 1106 Old 06-13-2012, 06:28 AM
TroubleNEO
Thanks for your input, like I said I have not dealt with Tattons. Good customer service is one way to win my business, and get me to recommend you to others, and that's what I do with TW after my experiences.
post #750 of 1106 Old 06-13-2012, 07:26 AM
RubiconChris
Thanks for the replies on Tatton and Tom Woods. Its nice to here good things about companys standing behind their products. I dont mind spending the cash as much when I want to give someone my buisness.
So I also want to purchase the Novak shifter cable and install it and the driveshaft before I purchase the Transfer case skid to cut down on the install time. Is this a bad idea? Its my daily driver and dont want to tie it up more than a day.
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 01:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 04:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 01:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 06:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
