So you want a Tummy Tuck... - Page 48 - JeepForum.com
 1Likes
post #706 of 1106 Old 06-01-2012, 12:58 PM
biffgnar
biffgnar's Avatar
Originally Posted by BioTex View Post
Yeah, I realize about the tire size vs. angle thing, but I was just trying to throw out all the mods I'm doing so it might save some time later. I agree that a TT and BL go hand in hand from what I'm seeing so far. I will even have to purchase a TC shifter, but for now my only concern is to NOT have to replace the 4" springs with something like 2 1/2" springs due to the steepness of the drive shaft.
Last night I install the Metal Cloak front fenders, and boy that makes those 33's look small...
If it really does turn out to be too much but you want to keep the lift, don't forget that there are options beyond a standard double cardan driveshaft that can handle more angle. Yes, they do cost more but they exist. For example, look at TW superflex ujoints or BAMF CV joint.
Romney in 2020!
biffgnar is online now
post #707 of 1106 Old 06-01-2012, 01:00 PM
jeepinhokie
OK, sounds like you know what your doing then. just trying to cover the basics.
but i guarantee someone here has a 4"SL with a TT that can give you some solid advice. good luck.
PS. post a picture of 4"SL with Metalcloaks and 33s.
HOKIES UNITED!
jeepinhokie is offline
post #708 of 1106 Old 06-01-2012, 01:05 PM
BioTex
Gottcha, and thanks. To be honest, I wouldn't mind getting rid of everything R.C. on my TJ. I already ordered the bilsein shocks from Kolack. I'm just doing it a little at a time so the wifey doesn't get too wise!
I'm not sure I even need a TT, but hate the looks of the shovel enough that I will probably do it.
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #709 of 1106 Old 06-01-2012, 01:20 PM
Imped
Imped's Avatar
You're telling me you've never hit the stock skid?
Try not to dig around too much. Looking at pictures of flat bellies will make you hate that stock POS skid with a passion.
OlllllllO
IndyORV
Imped is offline
post #710 of 1106 Old 06-01-2012, 01:38 PM
BioTex
I hate to admit this, but I have not wheeled the Rubicon yet! I've done my share of crawling in my CJ, but just got the Rubicon a few months ago. I do know that the shovel will hit at some of the places I want to go.
Oh, trust me I already have the bug!
I love the looks of the longarm with a TT also, but I really need to be realistic at least for the short term. I'm ready to wheel, tired of it sitting in the shop all lonely. Hopefully after this weekend I'll have the armor installed.
BioTex is offline
post #711 of 1106 Old 06-01-2012, 01:43 PM
polo196
I ordered my UCF skid, which shipped last Thursday, 3 day UPS. The wagon train it is coming on must of got held up somewhere in Texas. Know anything about that BioTex
Wow, I'm a member. Thats not the word I'm normally called.
Yellow Jeep Club Member #196
polo196 is offline
post #712 of 1106 Old 06-01-2012, 02:18 PM
BioTex
Maybe the truck fell into the hole my shovel dug??? Frustrating isn't it? Where I live there is no such thing as next day. If you pay for next day, it still comes two or even three days. I just learn to live with it.
Keep us posted on the install though. I'm probably going with UCF also. (if the D.S. angle supports it)
BioTex is offline
post #713 of 1106 Old 06-01-2012, 02:52 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
The UCF ultra high clearance TT is doable with a 4" short arm lift, but you will need a 1.25" body lift, a 1" motormount lift, a Novack cable shifter, and you will need a quality CV rear driveshaft.
My newest build:
Necromancer_tat is offline
post #714 of 1106 Old 06-01-2012, 03:02 PM
Imped
Imped's Avatar
And preferably a super short tail housing.....
Bottom line: Do whatever you can to make the drive shaft as long and as flat as possible.
OlllllllO
IndyORV
Imped is offline
post #715 of 1106 Old 06-03-2012, 01:37 PM
AMCMasterTech
I'm using the Nth TT, but it's all new territory as far as how it would all set-up with the TDI. I may need to lift the body at this point, but we'll see how it drives-out. Other than that, it came together well.
"Hit em' where they ain't"
Roy D. Chapin Jr.
AMCMasterTech is offline
post #716 of 1106 Old 06-03-2012, 04:54 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Is your rear pinion shaft a bit low?...
Knuckelhead is offline
post #717 of 1106 Old 06-03-2012, 05:33 PM
AMCMasterTech
I'll know when it moves in a couple weeks. I'm not comfortable dialing the uppers out any more as it is now, and I can't get anymore tilt at the engine. If the vibes are unacceptable on test drive, then I'll figures something out.
I suppose I could install a xfer case drop kit on the TT...
Roy D. Chapin Jr.
post #718 of 1106 Old 06-03-2012, 06:16 PM
Imped
Imped's Avatar
Your lowers are likely longer than stock and are fixed. That's a problem.
OlllllllO
IndyORV
Imped is offline
post #719 of 1106 Old 06-03-2012, 06:22 PM
Knuckelhead
AFSOC Retired
Get adjustable lower control arms...
post #720 of 1106 Old 06-03-2012, 06:51 PM
clg82
Is a SS sye mandatory for all tummy tucks?
clg82 is offline
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 02:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 05:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 02:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 07:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 06:31 AM
