So you want a Tummy Tuck... - Page 46 - JeepForum.com
 1Likes
post #676 of 1106 Old 05-30-2012, 03:43 PM
jeepinhokie
I'm not looking for more travel or anything. Just thinking about what I'm going to do if my pinion angle needs to be raised so much so that the shock makes contact
HOKIES UNITED!
jeepinhokie is offline
post #677 of 1106 Old 05-30-2012, 03:48 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Originally Posted by boilerup1998 View Post
Necro, not sure why your shocks were so compressed originally. Here's what mine look like with no mods to shock mounts.
Attachment 406127
If you look, your shock body is above your spring pad, while mine are below my spring pads for some reason.
My newest build:
Necromancer_tat is offline
post #678 of 1106 Old 05-30-2012, 03:53 PM
biffgnar
biffgnar's Avatar
Grind down the spring perch. Easy.
Romney in 2020!
biffgnar is offline
post #679 of 1106 Old 05-30-2012, 03:58 PM
Necromancer_tat
2015 JK Wrangler
Yep! They also make shock relocation brackets to space them out away from the coil buckets as well. I'm pretty sure Currie makes a nice set.
My newest build:
post #680 of 1106 Old 05-30-2012, 04:00 PM
biffgnar
biffgnar's Avatar
Had those for awhile. Seemed like they would increase leverage on the mounts though.
Romney in 2020!
biffgnar is offline
post #681 of 1106 Old 05-30-2012, 04:07 PM
Necromancer_tat
2015 JK Wrangler
Yeah, there's that then isn't there? Anything that spaces the shock outwards will increase the load on the factory shock mounts. I think that if the bump stops are set up correctly the shock will extend and colapse without over exerting to much pressure on the factory mounts even if they're extended a bit. But if the bump stops aren't set correctly the added leverage could easily rip a shock mount off the axle IMO.
My newest build:
post #682 of 1106 Old 05-30-2012, 06:03 PM
boilerup1998
What's the length of your shock body? Distance from upper mount to spring pad?
boilerup1998 is offline
post #683 of 1106 Old 05-30-2012, 06:08 PM
Necromancer_tat
2015 JK Wrangler
I've got no clue, it's been tropical storming here all day, remind me tomorrow afternoon and I'll go take a measurement.
My newest build:
post #684 of 1106 Old 05-30-2012, 07:05 PM
jeepinhokie
That's my plan for now, just wanted to look into alternatives. Will I be able to grind down enough of the spring perch for 3" of lift with a flat skid? With a 42rle auto? I know this set up might cause a pretty severe driveshaft angle and pinion angle. Just trying to cover my bases
HOKIES UNITED!
post #685 of 1106 Old 05-30-2012, 08:28 PM
biffgnar
biffgnar's Avatar
I have 3" springs front/2" springs rear (BDS) and UA and no problem grinding down enough. Oh, and I had 42RLE and D44 which I think results in the shortest stock driveshaft.
Romney in 2020!
biffgnar is offline
post #686 of 1106 Old 05-30-2012, 08:40 PM
jeepinhokie
I have 3" springs front/2" springs rear (BDS) and UA and no problem grinding down enough. Oh, and I have 42RLE and D44 which I think results in the shortest stock driveshaft.
Good to know. Thanks.
Hopefully I can keep my output shaft as low as possible with my crossmember. While still getting everything tucked up as much as possible ( within reason)
HOKIES UNITED!
post #687 of 1106 Old 05-31-2012, 08:36 AM
geiman
I have 4" springs, a 42RLE, and the UA from Savvy and I was able to grind the perch enough to clear the shocks as well.
geiman is offline
post #688 of 1106 Old 05-31-2012, 02:44 PM
conquest255
Not sure if I posted the photo link correctly, but did want to share my flat skid I recently completed with inspiration from "Imped". I used 1/4 in 6061 alum for both the engine and transfer case skid, with angle to reinforce. I have a 02 TJ with 5 sp, with 1" MML and BL. I had plenty of room and ended up using the factory transfer case mount without much trouble. The only real pain was adjusting the exhaust to clear the front control arm bracket. No vibes with lots more clearance
conquest255 is offline
post #689 of 1106 Old 05-31-2012, 02:58 PM
Necromancer_tat
2015 JK Wrangler
Looks great! Nice work!
One thing though, I notice your zerk fitting on the front lower control arm facing rock rash side down, I would flip that over if I was you so you don't break it off inside the JJ.
And I have those exact same tires on my rig, I love them! They stick like bubblegum in hair when I air them down, they flex awesome, and self clean really well. They're also pretty quiet on the street as well.
My newest build:
post #690 of 1106 Old 05-31-2012, 03:10 PM
Imped
Imped's Avatar
That's a mighty sexy skid there.....nicer (and lighter) than mine. You should look into a HP30 now so you can get a better mix of pinion/caster.
OlllllllO
IndyORV
Imped is offline
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 02:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 05:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 02:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 07:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 06:31 AM
