So you want a Tummy Tuck... - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > So you want a Tummy Tuck...
Oconee off-road New Store Location 2012Huge sale at Oconee Offroad dont miss the savings!JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 01-21-2010, 06:35 PM   #271
lumpster
is that a trick question?? LOL
For most, corner guards and and rocker guards are not needed. How many people that have those addons have never used them? i would say most of the people that buy them are doing so to look cool, and if its your DD why not put the lighter parts on. If nothing else it will save you gas.
I jsut thought of something, why not make aluminum corner guards and rocker guards out of aluminum tape. Cheaper, lighter and used just as much as most peoples 3/16 or 1/4 inch thick stuff.
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, DELRIN DOOR BUSHINGS, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Unread 01-21-2010, 06:42 PM   #272
rsbmg
I hear what your saying, I was simply implying that money would be better spent in other areas prior to arriving at the NEED for lighter body armor. I agree for many it completes a "look". Perhaps at this moment I fall in that category but its also in anticipation of getting my rig to the point where I will need them and in fact use them.
rsbmg is offline   Reply With Quote
Unread 01-21-2010, 06:45 PM   #273
mrblaine
mrblaine's Avatar
You really believe that to be the case? If so, I'm so far out of the loop as to not even be on the same planet.
I blew off our stock side steps within an hour of owning our rig and that was on some very mild trails. My first upgrade was a set of rock rails.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 01-21-2010, 06:47 PM   #274
LuckRider
LuckRider's Avatar
Originally Posted by undercoverfab
Our 3/16" steel skid weight in at 62 lbs. Our 1/4" steel skid weights in at 77 lbs. Our 1/4" aluminum skid weights in at 27lbs.
The alloy of aluminum (6061-t6) we are using has a higher yield strength than A36 steel plate (probably what most people would call "carbon steel") but has a lower ultimate tensile strength. This could be described in simpler terms by saying that assuming an equal thickness steel and aluminum skid plate, the steel skid would start to bend before the aluminum skid; but the aluminum skid would also "fail" before the steel skid.
There are of course other factors to consider when choosing a material, but these are two of the more important properties to look at.
I don't post in threads where my products are mentioned because I don't yet have a vendor star.
Thanks,
Well... I was pretty close with the weight of the steel skid from UCF. I was off by 8lbs which I would account for by saying that the part that crossmember is the same weight in both, and there is no weigh savings there. I like that UCF is at least watching this thread to be able to answer questions from forum members (I don't think it avoids the no soliciting rule either since we are asking for the info).
Now for Blaine... I love the way you describe the reasons for the weight savings in your last 2 posts. They make perfect sense, and go farther than just saying we do this. YOu go to explain why it isn't the right way to go for everyone. With that said, I still think that the weight savings have other uses than in the hardcore rocks (some of your rocks are the size of your rigs, when I first saw that, I never thought it was possible). Since many of our Jeeps spend a lot of time on the road, the extra weight savings helps with vehicle wear and mileage. As for your question, I would rather have a TJ with 31"s on a 2.5" lift rather than a TJ with extra heavy armor lifted 3.25".
I should also address the cost of AL. The difference isn't that much more $$, and the benefits are worth it. Rocker guards aren't useless, my steps have a big dent from dropping them on a rock, and I am considered by other forum members to not actually use my Jeep.
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote
Unread 01-21-2010, 06:53 PM   #275
Kiwi
Kiwi's Avatar
Yes I believe that. I see all sorts of Jeeps running around here with all that stuff on with nary a scrape or scratch on them.
Maybe you should have let Kat drive your new rig
Kiwi is offline   Reply With Quote
Unread 01-21-2010, 06:58 PM   #276
MudDuck99
MudDuck99's Avatar
anyone got a weight on the ROKMEN skid? Wasn't posted on page 1
MudDuck99 is offline   Reply With Quote
Unread 01-22-2010, 08:18 AM   #277
Deacon
Deacon's Avatar
I tried to talk Blaine into making a mini boatside version of his rockers because I tried to get away without them too long and have already had the process of hammering in the rocker panel lip begun for me by a rock at Long's Ranch.
Deacon is offline   Reply With Quote
Unread 01-22-2010, 08:26 AM   #278
REDLYNER
Mall Crawling Race Rig
REDLYNER's Avatar
I'm not quite sure how to respond....
I can not remember the last trip I went on where I didn't hit my rocker guards. Seriously, I can't remember not hitting them. If you aren't dragging your rockers over an obstacle, or squeezing your rockers between a v-notch, you are missing out on a whole world of awesome in the sport of off-roading.
REDLYNER is offline   Reply With Quote
Unread 01-22-2010, 08:34 AM   #279
Imped
Imped's Avatar
Agreed. Rocker guards should be #3 behind oil pan and steering box skids, which are cheap and functional. All three will save your *** every time you wheel.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 01-22-2010, 08:51 AM   #280
mrblaine
mrblaine's Avatar
There will be a boat side version at some point, but there's a bunch of other stuff that has to be finished up first.
Heading down in a few minutes to final up the rear bumpers and no, there are no teaser pics.
I am Savvy
Unread 01-22-2010, 09:22 AM   #281
DaleII
Awwhh man.. I like looking at the purrty stuff..
Anyway we should get back on topic. Blaine, how is the TT coming along? Some good news I hope? Also shouldn't the LJ stuff be coming along well?
2005 Silver LJ
DaleII is offline   Reply With Quote
Unread 01-22-2010, 09:37 AM   #282
lumpster
I wasn’t really referring to JF people for the most part. How many JK's have you seen with 20's or bigger rims and had serious off-road accessories like winch, bumpers, rockers, ect..
I’ve seen several tj's setup the same way; I would say half of the stuff you sell will never touch a rock, maybe a minivan or Honda, but not rocks.
To anyone that thought I was saying you don’t use your stuff, I was not, unless you don’t.
Want to STOP?
Unread 01-22-2010, 09:40 AM   #283
lumpster
oh yes, lets hear it.
Want to STOP?
Unread 01-22-2010, 09:43 AM   #284
mrblaine
mrblaine's Avatar
The Unlimited stuff is almost done. Corners, rock rails and tub backers are done, tub rails are almost done.
I am Savvy
Unread 01-22-2010, 09:44 AM   #285
Goobersbro
well for what its worth I have never seen anyone around here with tubes / true rock sliders/ or full corners that didn't wheel their rig....Most guys who just buy cool stuff by Smittybuilt side steps diamond plate small corner guards and bushwacker flairs
My marshmallow build
http://www.jeepforum.com/forum/f12/m...-build-873442/
Goobersbro is offline   Reply With Quote
