so the sahara turned 30K autotrans oil change? - JeepForum.com
post #1 of 8 Old 07-26-2005, 12:28 AM Thread Starter
zband
zband's Avatar
I would like to change the transmission oil in my 4 sp auto. I hear that you need a machine that the dealship has to do this - what kind of oil should I replace it with?
One last q- I think that they dont change the oil rather they put new oil in as the old old recycles- am I getting ripped off?
zband is offline
post #2 of 8 Old 07-26-2005, 07:16 AM
Hunter9
Hunter9's Avatar
Opinions vary on the use of Transmission Flushing Machines, frequently used at dealerships and quick lubes. I guess I have always looked at it like changing your oil and not the oil filter .
I have always changed the tranmission filter and oil in all of my vehicles that had autos. I really do not want the junk in my trans pan flushed through the entire trans only to leave the old used (plugged) filter in there.
But, you know what they say about opinions.
97 Sport 4.0l Auto D30/D35
RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion
Former 3.07 Gears Club Member #1
Hunter9 is offline
post #3 of 8 Old 07-26-2005, 07:21 AM
otisdog
2008 WK
Mine's coming up on 30k. The dealer I deal with told me for the 30k service that they just drain the pan and change the filter and adjust the bands.
jim
08 Grand Cherokee Overland
otisdog is offline
post #4 of 8 Old 07-26-2005, 01:03 PM
lupinsea
lupinsea's Avatar
Supposedly just dropping the pan and draining the fluid only gets 60-65% of the old fluid out. The machines you can hook up to at the lube shops that flush the transmission fluid out (actually pump out the old fluid while adding new fluid) are said to replace 90-95% of the old fluid.
Having the bands adjusted might be a good idea. I'm going on 49,000 miles and I don't think mine have been adjusted. It's on my list of things to do.
- Jay
lupinsea is offline
post #5 of 8 Old 07-26-2005, 02:26 PM Thread Starter
zband
zband's Avatar
The 4 speed auto in the 2003+ don't have bands.... any suggestions on trans oil. I would rather use something that is good....
zband is offline
post #6 of 8 Old 07-26-2005, 03:02 PM
otisdog
2008 WK
well it's nice to know the service man knows nothing. I'll just be doing it myself.
Probably the best is to spring for the Mopar ATF-4 which is what it calls for. I don't know if there is anything else that meets the requirements for ATF-4. Of course this means getting stung real good.
Jim
otisdog is offline
post #7 of 8 Old 07-26-2005, 04:42 PM
lupinsea
lupinsea's Avatar
Ha! I guess it's just the older 3 spd autos that have the bands, which I've heard need adjustment from time to time.
Apparently the ATF +4 was superceeded by ATF +5 which is now becoming more common. The higher the "+" number the more compatible it is (you can use a +4 in a +3 application but not the otheway around, for instance). Unfortunately, the +4 and +5 ATF is still new enough that you won't be finding it on the shelves of your local auto parts store. So it's a dealer only availability so far.
The good new: when I recently picked up the ATF+4 to top off my tranny the dealer ship was only charging $3.99 or $4.99 per quart. I figure that's pretty close to aftermarket prices that I don't feel I'm getting taken to the cleaners.
- Jay
lupinsea is offline
post #8 of 8 Old 07-26-2005, 09:12 PM
StealthTJ
jim
If that's truely what the dealer told you, I'd find another place to work on the Jeep.
The dealer is truely clueless.
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
mc2100 autotrans bracket DonAltman3 YJ Wrangler Technical Forum 4 10-09-2009 02:09 PM
Autotrans will not shift when floored! help please! jh1328 TJ Wrangler Technical Forum 3 09-15-2009 06:56 AM
Autotrans making chainsaw sound TheMatrix TJ Wrangler Technical Forum 16 01-08-2009 03:12 PM
Transmission change - 95 Sahara barnhillld YJ Wrangler Technical Forum 25 09-11-2005 09:32 PM
changing the autotrans fluid. Suggestions? zband TJ Wrangler Technical Forum 4 03-04-2004 11:37 AM
