So my D44 walks into a bar.... - Page 2 - JeepForum.com
post #16 of 22 Old 03-28-2013, 02:21 PM
freeskier93
You really think that little spring would've done damage? The ring and pinion likely would've chewed it up over and over until it was nothing more than dust....or it would just chill on the magnet.
Order these:
http://www.jeep4x4center.com/wheel-b...-83503064.html
http://www.jeep4x4center.com/axle-be...-83503077.html
http://www.jeep4x4center.com/seal-wh...-83503063.html
http://www.jeep4x4center.com/retaine...5083678aa.html
The R&P definitely wouldn't be the issue, I'd think it could tear up a bearing though.
freeskier93 is online now
post #17 of 22 Old 03-28-2013, 02:25 PM
rubidriver
DO NOT. I repeat, DO NOT use anything other than a SKF (aka chicago rawhide) seal and if you can get a Timken Bearing, do it. The seal is a little bit more expensive than some of the others, but not when you consider you will go that route anyway when the cheap seal leaks because it will. The seal can be found at NAPA (NOS 18731) and the bearing can be found at Autozone (set 10).
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #18 of 22 Old 03-29-2013, 10:06 AM Thread Starter
Hosejockey61
Anybody else agree or disagree with this statement? Reasons why?
Hosejockey61 is offline
post #19 of 22 Old 03-29-2013, 11:29 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
And the girl you leave with says, "I thought you said you had a big d44".All I see is a tiny d35.
TheBoogieman is offline
post #20 of 22 Old 03-29-2013, 11:59 AM
rubidriver
Timken is the OEM bearing and SKF is the OEM seal. Its like going to the dealership except you are paying less. I used a carquest bearing and seal (National bearing and Federal Mongul seal) and it leaked worse than the bearing and seal that gave me reason to replace it in the first place. Trust me.
post #21 of 22 Old 03-29-2013, 03:02 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Originally Posted by tomsrancho View Post
...and, the bartender said, "I thought you were locked up!"
Best post in this thread!
My newest build:
Necromancer_tat is offline
post #22 of 22 Old 05-29-2013, 10:32 AM Thread Starter
Hosejockey61
Hey guys, I just wanted to follow up with another question that didn't get answered.
I bought new parking brake assemblies for my rear...I still need one piece though.
In the picture, it is the actuator lever. The cable attaches to it and engages the brake. The second picture shows the other side (behind the purple spring). I contacted the dealership and their not sure if it's the right part or not but they want $45 for it. Any other ideas where I might find one?
axle , d44 , Rubi D44 axle seals , seal
