So my D44 walks into a bar.... - JeepForum.com
post #1 of 22 Old 03-27-2013, 07:19 PM Thread Starter
Hosejockey61
Ok....just wanted to get your attention...
I am (finally) preparing my used '05 Rubi D44 for a swap out with my D35. I have THREE questions.
Let me preface this with the fact that I have never messed with an axle myself until now. I am really glad I jumped in as it will really benefit me on the trail should I break down.
Question 1:
I want to sandblast and paint the axle prior to install. I pulled the axle shafts and a long spring came out with it (all bent up...see pictures). After comparing to the other axle shaft, it appears that it came from the axle shaft seal. Do I need to replace the whole seal or can you simply (or not so simply) slide another spring into place on the seal?
This is the spring in question:
The first picture here shows where the spring is on the other shaft...the second shows it missing...
Question 2:
The driverside parking brake assembly was missing when I bought it. Is there another model (XJ ZJ years?) that I could pull the assembly from for a direct swap? I need everything including the hook the parking brake attaches to.
Question 3:
Before I go and break it, how does the brass fitting for the brake lines come off of the axle tube? Would it be better to leave it in place when sandblasting?
Hosejockey61 is offline
post #2 of 22 Old 03-27-2013, 07:54 PM
cfmiller58
the entire bearing seal assembly will have to be replaced. check out stu olson's website for a great write up.
http://stu-offroad.com/axle/d44/d44-1.htm
i believe there are some common parks for the break assembly, worth some further research on the forum, but i'm sure someone else will chime in.
that peice just turns off.
Black Jeep Society
cfmiller58 is offline
post #3 of 22 Old 03-27-2013, 09:33 PM
jeepvette1
To take off the brake line UN bolt the vent tube its what holds it on
jeepvette1 is offline
post #4 of 22 Old 03-27-2013, 09:48 PM
scot68
If your going to blast the housing reinstall the axles. Also remove the hose block and reinstall the breather tube fitting and cap it off. You dont want blasting media in the axle housing.
BTW I like your thread title.
scot68 is offline
post #5 of 22 Old 03-28-2013, 01:13 AM
rbkelley89
u can reuse your d35 brakes on your d44
2001 orange tj 2.5L (113,000) 35" Km2 Black rims D lp 30 Front and d 44 rear with ARB 1"BD MML, 1.25" BL, 4" RC Lift, Flat tc Skid, Adj rear ca's (front soon) TW rear DS, Novak shifter cable, JB ss SYE, RE angled rear trackbar, 8,000Lb Mile marker, Custom front and rear (w/swing) bumpers. Homemade CAI. Lots more to come.
rbkelley89 is offline
post #6 of 22 Old 03-28-2013, 02:30 AM
Necko2529
Necko2529's Avatar
Well, the title sure as heck got me. I thought you had backed up into a bar, literally.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #7 of 22 Old 03-28-2013, 07:03 AM Thread Starter
Hosejockey61
Negative...my D35 has drums, the D44 has discs
post #8 of 22 Old 03-28-2013, 07:06 AM Thread Starter
Hosejockey61
I'm actually going to use plumber style inflatable plugs in the axle tubes.
post #9 of 22 Old 03-28-2013, 08:27 AM
Robert J. yates
Not exactly.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #10 of 22 Old 03-28-2013, 10:35 AM
freeskier93
Dang, your pretty lucky that spring didn't make its way into the diff.
freeskier93 is offline
post #11 of 22 Old 03-28-2013, 01:03 PM
tomsrancho
...and, the bartender said, "I thought you were locked up!"
tomsrancho is offline
post #12 of 22 Old 03-28-2013, 01:06 PM
frenchy206
Nice!
03 TJ Rubicon
frenchy206 is offline
post #13 of 22 Old 03-28-2013, 01:51 PM
rbkelley89
Oh well if it was the drum brakes u could sounds like u have the rubicon axle then
post #14 of 22 Old 03-28-2013, 02:03 PM Thread Starter
Hosejockey61
Bump for brake parts options....
post #15 of 22 Old 03-28-2013, 02:19 PM
Imped
Imped's Avatar
You really think that little spring would've done damage? The ring and pinion likely would've chewed it up over and over until it was nothing more than dust....or it would just chill on the magnet.
Order these:
http://www.jeep4x4center.com/wheel-b...-83503064.html
http://www.jeep4x4center.com/axle-be...-83503077.html
http://www.jeep4x4center.com/seal-wh...-83503063.html
http://www.jeep4x4center.com/retaine...5083678aa.html
The breather/brake junction bolt just unscrews. E-brake, I don't know. I don't use those parts.
OlllllllO
IndyORV
Imped is offline
axle , d44 , Rubi D44 axle seals , seal
