So how many gallons does my Jeep hold? - JeepForum.com
post #1 of 13 Old 02-04-2006, 10:17 AM Thread Starter
Achped
I've got a 99 4cyl SE, owners manual says I have a 15 gallon tank....
Why did my Jeep take 18.36 gallons after driving about 15 miles after the light first turned on?
When topped off, my gauge is about 1/4" passed full and it doesn't even get to the full line until I've driven about 20-30 miles.
3.5 gallons is alot to have "in the lines" or "on the bottom of the tank".
Is it possible someone did the tank mod to my Jeep? I bought it from a chick, but the first owner did some mild offroading, it has nice Hella fogs, insanely backspaced rims, hooks, and a few other things.
However other times, it'll be a mile or two away from the light turning on and it'll take 14.5~ gallons.
Is there a way to know for sure how many gallons it holds? I don't wanna run it dry, but it'd be nice knowing how many gallons I have for off-road trips and such.
Achped is offline
post #2 of 13 Old 02-04-2006, 10:32 AM
Q-01
Ive been curious about that too...I mean what the standard tank is supposed to be. Ive never been able to put more than 12 gal in mine after driving with the light on on EMPTY for quite a while...
Q-01 is offline
post #3 of 13 Old 02-04-2006, 10:35 AM
Masterchief
Mine always fluctuates like that too. Is it due to a vacuum leak or what? And it is a little bit scary when you go back to check on the pump and you've nearly put 20 gallons of gas in a 15 gallon tank. On long road trips I guess its kinda cool cuz you can last a little bit longer but it doesn't even make that much of a difference when you're getting 11 miles to the gallon.
Chef
'98 TJ lifted by Teraflex 6"
Masterchief is offline
post #4 of 13 Old 02-04-2006, 10:37 AM
tacjeep99
According to my 99 sales Brochure the 15 Gallon tank was standard on the SE and the 19 gallon tank was optional. I would say your Jeep was ordered with the 19 gallon tank instead of the standard tank.
tacjeep99 is offline
post #5 of 13 Old 02-04-2006, 01:00 PM
bloke279
bloke279's Avatar
2015 JK Wrangler
x2 on the 19 gallon tank.
Even though i have a completely different jeep, i run into the same problem... well, not really a problem though.
I have an 05 X, and it has the 19 gallon tank. After driving with the gas light on, for quite a while, i can only get 17 gallons in it. The manuel says that the light comes on when there is only 2 US gallons left in the tank. I dont get that good of gas mileage!
2015 JKU
BB, Rubi wheel/tire, Barricade sliders
Ordered:
Synergy Ball joints, gussets and sleeves
Saving for:
4" short arm, 35's, bumper/carrier, e-locker and gears
bloke279 is offline
post #6 of 13 Old 02-04-2006, 01:20 PM
jameskjeep
I have a 05 X also and it has a 19 gallon tank. How long can you last when the light comes on
2005 Black Jeep Wrangler X 6 speed
Python Security System With remote locks
7 Speaker sound system + 2 12" MTX Thunder 6000 Subs
1.25 JKS BL
2.5 OME HD Sup Lift 1 inch JKS MML 32" BFG MUDDS
MT Classic 2 15x8
jameskjeep is offline
post #7 of 13 Old 02-04-2006, 02:09 PM
joedirt88
If you contact Jeep.com and request a build sheet...its tells you everything you jeep came with.
http://www-5.jeep.com/wccsapp/univer...ull&category=U
joedirt88 is offline
post #8 of 13 Old 02-04-2006, 04:03 PM
bondo303
bondo303's Avatar
Sorry to hijack........My build sheet shows a 19 gallon tank but when I fill it, it never comes close to 19 gallons. Once I let it go down to "E" and when I filled it up, it only took 13.5 gallons which leads me to believe that I have a 15 gallon tank. Does anyone know where on the tank the part # is located and what the part # is for the 19 gallon tank.
Thanks......
-Bondo
02 X Amber Fire
48 CJ2A
bondo303 is offline
post #9 of 13 Old 02-04-2006, 04:24 PM
Wrangler-x
Probably got the 19 gallon tank. But the reason for the fluctuation in how much it holds, I think, is probably because of something simple like ... you went up a hill, and your gas level was read differently because the fluid shifted, so the light came on at that time. And I am pretty sure if that happened, when you evened out, your light wouldn't go off. Just an opinion, I know that's what happens in a car we have, and I'm not familiar with how the tank is read on the particular Jeep, but it's possible.
Wrangler-x is offline
post #10 of 13 Old 02-04-2006, 04:56 PM
Nickb1907
Nickb1907's Avatar
7 gallons of gasoline
Nickb1907 is offline
post #11 of 13 Old 02-04-2006, 04:58 PM
Wrangler-x
I agree.
post #12 of 13 Old 02-04-2006, 05:45 PM
ncb76
ncb76's Avatar
The easiest way to find out for sure is to check the part number on the side of the tank. I've lost my parts manual, so I can't give them to you. Try a search, I've posted them before.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #13 of 13 Old 02-04-2006, 05:54 PM
silver97tj
silver97tj's Avatar
hi it is the same tank, other then a diffrent gauge/fuel sending unit for 19 gallon, you can make a 15 gal into 19 gal by taking out fuel tank and cutting fuel fill hose inside, the 15 gal goes deeper into tank, just have to use 15 gal gauge and remember or locate 19 gal gauge and use.............
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
When driving jeep does not hold idle. Rpms just drop and Jeep stalls myoung YJ Wrangler Technical Forum 9 02-26-2010 09:22 PM
Will the plastic pieces that hold the soft top on hold a bike rack? Keesh TJ Wrangler Technical Forum 7 08-29-2009 08:37 PM
Jeep won't hold battery charge Billyjon1 TJ Wrangler Technical Forum 4 09-11-2008 09:49 AM
Wow.. My Jeep can actually hold stuff! Fierdon JK Wrangler Technical Forum 6 03-17-2008 07:59 AM
convert 15 gal tank to hold 19 gallons for free? FLATFENDER54 TJ Wrangler Technical Forum 27 06-25-2006 08:09 PM
