So...how does an Aussie locker work? Any on-road issues? - JeepForum.com
post #1 of 10 Old 05-27-2006, 09:57 AM Thread Starter
Achped
2017 JK Wrangler
I can't believe I've missed out on these. I looked into them after I got pounced on for buying so many lights, which, with the money, people told me I could've locked my D30 for.
How do they work? This Jeep is my DD and I don't want any on-road issues, but at the same time, I don't want to spend 250 bones just to have a marginal effect offroad.
How do they lock and unlock? Are they (aside from a tad bit of noise) invisible on-road?
I looked at the install on 4x4xplor and its a no brainer install, but what about the effects of having one on?
Achped is online now
post #2 of 10 Old 05-27-2006, 10:05 AM
FlaJeepin
Good question. I've been wondering the same thing.
FlaJeepin is offline
post #3 of 10 Old 05-27-2006, 10:57 AM
adam728
They act the same as any other lunchbox locker on the road, you WILL notice it. In tight corners it clicks and clunks. When shifting it will sometimes grab and really pull the Jeep one way or the other. It will squeel the inside tire in a corner if taking it while on the gas. It's totally livable once you learn how to drive with it, but you will still know it is there.
If you want absolutly no on-road issues than a selectable locker is your only choice.
adam728 is offline
post #4 of 10 Old 05-27-2006, 11:54 AM
thefreak220
He is asking about the dana 30. You will NOT notice it in 2wd on the street except for some clicking when turning at low speeds. It will not grab you and jerk the jeep when you give it gas or make the tires squeel. Just get one and install it and be done with it. It makes a huge difference offroad.
thefreak220 is offline
post #5 of 10 Old 05-27-2006, 11:57 AM
jcd
jcd's Avatar
Here's the detailed 'how it works' from Aussie.
2008 Jeep Sahara Unlimited
Terraflex 4" 35's 5.13
jcd is offline
post #6 of 10 Old 05-27-2006, 12:03 PM
CjinPA
CjinPA's Avatar
It makes a huge difference off road. You will be able to crawl up things you would have never even tried before. It will be the best $250 you spend on the jeep. I can't comment for on road because I have locking hubs. I unlock when on road and nothing spins inside the front diff thus no difference from before.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #7 of 10 Old 05-27-2006, 07:32 PM Thread Starter
Achped
2017 JK Wrangler
Oh, I see it now. So it really does "lock" the front differential.
I understand...it allows one to go faster, but not one to go slower than the engine speed. So if you're turning the tires at say, 100 rpms and making a left turn, the left tire must stay at 300 rpms but the right tire can go faster to compensate for the longer distance traveled.
Offroad though, if you've got one tire up in the air it must go at least 100 rpms because that's what speed the engine is turning it at. Gotcha...
post #8 of 10 Old 05-27-2006, 09:34 PM
miguelitojeep97
best bang for your buck! i love mine. got me through the Rubicon and anything that gets in my way. love it!! just buy it and thank us later!
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
post #9 of 10 Old 05-27-2006, 10:22 PM
adam728
My retarded mistake. I didn't read it thouroghly and assumed rear axle. Whoops.....
adam728 is offline
post #10 of 10 Old 05-27-2006, 10:31 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I can't tell my front axle has a locker inside when I'm in 2wd. It's a Powertrax No-Slip and it doesn't click, make noise, or in any other way make its presence known in 2wd. That's no matter if my front manual hubs are locked or unlocked. If I forget to unlock my front hubs after wheeling, there's no clue to remind me to unlock them so I may accidentally drive around for weeks with them locked.
So there's no reason to fear a front locker in a TJ and you don't need manual hubs unless you want them for other reasons as I did. A Lockrite acts about the same too, and I would expect an Aussie to be on a par with the others too... unnoticeable.
Gone on vacation until August 25.
Jerry Bransford is online now
Aussie locker VS. Yukon Spartan locker fishinjeeper TJ Wrangler Technical Forum 126 07-15-2015 05:55 AM
Lockright E-Z Locker VS. Aussie Locker Wheels4186 TJ Wrangler Technical Forum 42 10-19-2010 04:39 PM
aussie locker in D30 work with lower gears??? BennyV TJ Wrangler Technical Forum 9 12-17-2009 06:28 PM
What makes a Lock-right or Aussie style locker work? Mudbug1979 TJ Wrangler Technical Forum 4 05-19-2009 10:48 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
