Quantcast So... figured out what that odd clunking sound was. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > So... figured out what that odd clunking sound was.
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 04-22-2008, 06:42 PM   #1
TheMightyGoat
Yep, that'd do it.
Now then. Excuse my ignorance. What do I need to fix this? Looks like I need a new one 'o them boot deals. Is that the only part I'm going to have to replace? Where can I find one?
Is it unsafe to drive in the meantime?
TheMightyGoat is offline   Reply With Quote
Old 04-22-2008, 06:49 PM   #2
krawler510
You'll need the whole link. $20-30 probably. I had to replace both side of mine last summer but then lifted it in November, so I have fairly new ones just sitting the corner.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline   Reply With Quote
Old 04-22-2008, 06:52 PM   #3
bairy
Very very common problem.
I suggest looking for a pair of aftermarket swaybar disconnects.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline   Reply With Quote
Old 04-22-2008, 06:54 PM   #4
TheMightyGoat
What is the advantage to a swaybar disconnect?
Old 04-22-2008, 06:58 PM   #5
1CleanTJ
easier/faster to disconnect your swaybar when you go wheeling. disconnecting them when going off-road allows more flex, better ride and doesnt stress the end links out like that causing them to break.
1CleanTJ is offline   Reply With Quote
Old 04-22-2008, 06:59 PM   #6
raskull
It allows you to disconnect the sway bar for when you are on the trail. This allows your axle to move around (flex) more.. more wheels on the ground means better traction.
I agree with the above poster.. go with an aftermarket set like JKS. Keep in mind that if you lift your jeep you will likely have to buy a new set if the lift doesn't come with quick disconnects.
If you just want to fix it for now, check your local club's website and ask for a stock sway link. Chances are someone will have aftermarket ones installed and have some stock ones laying around for real cheap or free.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (pic)
http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery
Custom front bumper build
Custom rockers build
My build thread
raskull is offline   Reply With Quote
Old 04-22-2008, 07:14 PM   #7
TheMightyGoat
Thanks for the help people.
Old 04-22-2008, 10:56 PM   #8
SillyPutty
A pitman arm puller will make unseating that tapered bolt a lot easier.
SillyPutty is offline   Reply With Quote
Old 04-22-2008, 11:03 PM   #9
Crashnburn80
The other advantage not mentioned, is they wont break again, so you won't have to re-address this issue at a later time.
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 04-22-2008, 11:25 PM   #10
krawler510
And if you don't have/feel like getting one of those putting a pipe wrench on ball will rip it out. Might take a little heat if its in there really good.
Old 04-23-2008, 12:03 AM   #11
bman9089
You get what you pay for
bman9089's Avatar
I wish that happened to mine.
I had to torch the bushing to get it off.
JKS makes nice, beefy, noise free ones. Very easy to pop on and off.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Old 04-23-2008, 12:39 AM   #12
EvilM0nkey
i have a nearly new set of swaybar links. Let me know if you want them.
-Ross
1998 Subaru Forester DD
2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy
1987 Coleman Columbia
3/4 ton+ tow rig wanted!
EvilM0nkey is offline   Reply With Quote
Old 04-23-2008, 09:03 AM   #13
Faramir66103
Or you could make your own. Here's the thread I'm following:
Scotch740 better home brew disconnects
It could save you some money over the commercial offerings.
FWIW,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is online now   Reply With Quote
Glock Forum
