Snow Chains Prohibited on a Sahara? - JeepForum.com
post #1 of 50 Old 12-12-2009, 07:04 PM Thread Starter
stedwest
My father picked up an '02 Sahara this year, and with winter upon us, he decided to look into snow chains. The vehicle manual says however, that snow chains are not recomended, specifically for Sahara's.
It has the standard NV-231 transfer case, not some fancy AWD system... so I'm guessing this is because of the larger fender flairs? Any other ideas?
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline
post #2 of 50 Old 12-12-2009, 07:08 PM
fishinjeeper
alot of manuals dont recommend them. they have a tendency to come off and wrap about the axle. if a link breaks the chain just whips around tearing up the wheel wells
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #3 of 50 Old 12-12-2009, 07:10 PM
JeepNE
but why only Saharas and not all jeeps in general?
JeepNE is offline
post #4 of 50 Old 12-12-2009, 07:11 PM
wushaw
Rockin jeep
wushaw's Avatar
Interesting? Why just the Saharas, they just have painted flares and alloy wheels.
wushaw is offline
post #5 of 50 Old 12-12-2009, 07:16 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Yeah, the manual for my '01 Sahara says the same thing.
It also says (paraphrased): to use chains only on P205/75R15 or P215/75R15 tires. Larger tires do not have adequate clearance between the tire and flare.
I know Saharas came equipped with one of two tire sizes: 30X9.5-15 or P225/75R15 , so the 'Sahara Chain Restriction' seems to be based on tire size. (Back before the Rubicon, the Sahara was the high-end TJ with bigger tires than the other TJ models.)
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #6 of 50 Old 12-12-2009, 07:16 PM
fishinjeeper
there really is no difference that would have an effect that would matter about chains vs cables. atleast none i could think of. do sahara's come stock with limited slip? that might be the reason
post #7 of 50 Old 12-12-2009, 07:20 PM
SpaceWrangler
Gnarly Adventurer
Not stock. D44's were an option, though.
post #8 of 50 Old 12-12-2009, 07:27 PM
fishinjeeper
well, since it was the upgraded version of the jeep. and now the rubicon is...so does the rubi say the same thing since they are running larger tires?
post #9 of 50 Old 12-12-2009, 07:29 PM
SpaceWrangler
Gnarly Adventurer
Dunno. Does a Rubi have taller springs than a Sahara? They may have more clearance, Clarence.
post #10 of 50 Old 12-12-2009, 07:58 PM
iceman8
Jeep and other Mfr's do not recomment tire chains mostly because people will not install them properly or do not know how...and/or drive too fast after installation=chains come loose and damage the vehicle. Add the fact that many folks have the wrong size chains for thier tires to begin with...and the tolerance stack-up of it all can make for a real bad day. I cannot imagine chaining up unless I was plowing with a big truck, driving the Haul Road to Prudoe Bay in winter, etc. No thanks.
iceman8 is offline
post #11 of 50 Old 12-12-2009, 08:04 PM
SpaceWrangler
Gnarly Adventurer
I did that once. On a motorcycle.
in winter.
Oh. Nevermind.
post #12 of 50 Old 12-12-2009, 08:05 PM
WhiteOut
WhiteOut's Avatar
Its a clearance issue. As long as you use good chains and have enough clearance in the the wheel wells you will be fine. Limited slip and lockers have nothing to do with it, we run chains on Jeeps will lockers and LSD all the time.
WhiteOut is offline
post #13 of 50 Old 12-12-2009, 08:07 PM
shotgunsmith
Most of the owners manuals are written by lawyers try to avoid suits filed due to lack of common sense. Put the chains on, check the clearence. if it flies your good. I'm running 33-9.50 on stock wheels with 2" lift and I use chains because nothing is cooler then the crazy tration chains provide.
"If a law is stupid, you have to break it."
HST
shotgunsmith is offline
post #14 of 50 Old 12-12-2009, 08:12 PM
fishinjeeper
on trails or paved roads. i would that it would be hard on the front locker to have the chains dig through the ice onto the pavement.
post #15 of 50 Old 12-12-2009, 08:14 PM
iceman8
Yeah! All the last few posts are right on. AND...don't drive over about 30 mph (I say that because there is a high likelyhood of the chains getting loose...it will happen and the fact they are likely imported/cheap, don't help the matter). You'll be fine. I suspect however, that after your first install of a full set of chains, if you've not done it, then the experience of driving on same...and you'll be about done with all that. Of course there are some who need the traction and will go through the ordeal. Been there, done that. No more. I'll wait til' it warms up a bit!
iceman8 is offline
Never driven in Snow, chains go where? FR/BK herculz TJ Wrangler Technical Forum 3 11-07-2009 11:27 PM
Manual says no snow chains on Sahara or Rubicon Sia Bani TJ Wrangler Technical Forum 15 01-11-2009 01:07 PM
Lockers and Snow Chains? jeepboy21 YJ Wrangler Technical Forum 3 11-23-2006 07:40 PM
GoClaws snow/mud chains? remedy 66 TJ Wrangler Technical Forum 1 03-07-2006 04:59 AM
Snow and Chains SpitNine TJ Wrangler Technical Forum 9 02-17-2003 07:37 AM
