Snow and Chains - JeepForum.com
post #1 of 10 Old 02-16-2003, 11:31 AM Thread Starter
SpitNine
2015 JK Wrangler
Snow and Chains
FWIW
Had a chance to try my completely stock 2003 SE 5-speed in about a foot of old snow that nobody had driven in before.
Tires are stock Wrangler RT/S in 215/75-15.
Chains are RUD 4x4. These chains are very easy to install and slightly less easy to remove. They are a little pricey at $140.00 USD per set.
First tried using only 4WD Low and no chains.
Rough going. Could only go about four or five feet then wheels would start spinning and axles hopped up and down violently.
Had to back up and plow forward repeatedly. This was hard on the Jeep.
Second try was with chains mounted on REAR wheels. A little better but still had to back up and plow forward some. Not quite so hard on the Jeep.
Third try was with chains on the FRONT wheels. Major improvement. NO backing up and no axle hopping. Much easier on the Jeep.
I'm going to buy another set of chains.
I think a TrueTrac LSD in the rear axle would help a lot too.
Like I said, for what it's worth.
Thanks.
SpitNine is offline
post #2 of 10 Old 02-16-2003, 02:41 PM
Weelspin
OK.... now that is a new one on me. I have never used chains... ever. Not once. And I drove a Mustang, Probe, Avenger and various other sports cars in ALASKA! I have driven a 1987 Mustang through 3 mountain ranges in 2+ FEET of snow.... while it was still falling.... and broke trail! The first Jeep I had was a 1980 FSJ and I had to plow through 4 feet, with it going over my hood on the drifts. I'm not saying you can't drive, but consider either using 4 high alone or better tires. Chains and cables have the problem of tearing up roads once you do get back on the dry stuff and the vibration causes more harm than good.... the hopping you referred to may have been the wheels being over powered. Try the test again, but don't apply as much throttle. Just my input....
"Brave men die but once, but a cowardly man dies many times."
1998 Wrangler
Sahara Package
2.5" Suspension Lift
Weelspin is offline
post #3 of 10 Old 02-16-2003, 04:07 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Re: Snow and Chains
Originally posted by SpitNine
FWIW
Thanks.
At 140ea, it'd be worth the money money to ditch the chains and upgrade the tires into something better like a set of BFG Muds.
K9Jeep
K9JEEP is offline
post #4 of 10 Old 02-16-2003, 07:55 PM Thread Starter
SpitNine
2015 JK Wrangler
Tires
Better yet, for $140.00 I can buy that '87 Mustang!
Thanks.
SpitNine is offline
post #5 of 10 Old 02-16-2003, 08:15 PM
OverTheHandlebars
OverTheHandlebars's Avatar
I have found that the goodyear wranglers handle terribly in the snow....
'02 TJ, 2.5L 5spd
OME HD, JKS BL, Goferit MML,Aussie in the front
33x10.5 BFG muds on the stock steelies
OverTheHandlebars is offline
post #6 of 10 Old 02-16-2003, 09:04 PM Thread Starter
SpitNine
2015 JK Wrangler
Wranglers
I can agree with that. Everything I've read says the Wranglers really aren't that good in snow, or mud or anything else for that matter.
However a new set of four real snow tires just isn't in the budget for now. I'm thinking the chains will be a reasonable compromise. Thanks.
SpitNine is offline
post #7 of 10 Old 02-16-2003, 10:34 PM
OverTheHandlebars
I hear ya, i'll be riding on my wranglers until next fall at least....
anyways, slipping and sliding in the snow is a bit of an art form to me now
'02 TJ, 2.5L 5spd
post #8 of 10 Old 02-17-2003, 07:02 AM
GW
2015 JK Wrangler
Snow tires make a little difference, but not that much
I replaced my GSA's and put a set of Bridgestone winter duelers on my wrangler and it didn't improve all that much. Jeep still slides around in snow, even in 4wd. Problem must be the really short wheel base. I was pretty surprised how poor a wrangler is on snow covered roads.
GW is offline
post #9 of 10 Old 02-17-2003, 07:26 AM
Owen
Owen's Avatar
I just drove to work in over a foot of snow...30 miles...I have 35" BFG A/T and they are awesome in the snow (No Chains). I am officailly convinced that nothing can stop that Jeep. Aside from maybe an attack of locusts...I can't even tell you how many 2wd cars I passed spun out. I pulled one guy out of a drift with my tow strap (First victim I saw). I give one helping hand per day. The only cars that were actually moving were two Jeeps and one suburban (Going Very sLow)...
Smuggler Re-Born.....
Owen is offline
post #10 of 10 Old 02-17-2003, 07:37 AM
Jim Shanks
Jim Shanks's Avatar
Right after I got my TJ back in late '99 we had a pretty good snow season. The next day it snowed the first time that year.. Anyways, out by my house is a road that isn't traveled much so the plows don't care about it. It is also very flat back there and snow drifts alot. I remember pushing my bone stock 30" GSA wrangler thru snow that was so deep that it was rolling up against the windshield. It kept right on pushing thru. Granted it was the light fluffy stuff but it was still over 4' deep. I didn't have any chains, nothing, bone stock in 4Hi. Jeeps amaze me with what they can go thru. I haven't been stuck yet. (knock knock) but I'm sure one day I will find the limits. More than likely after I find a place here in Iowa that you can stick a Jeep. Now I have 32" BFG ATKO's and like them much more, drove thru a foot and a half of snow and it felt like I was on pavement. Didn't even slow me down. Still no chains.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
Snow Chains Prohibited on a Sahara? stedwest TJ Wrangler Technical Forum 49 01-07-2010 07:42 AM
Never driven in Snow, chains go where? FR/BK herculz TJ Wrangler Technical Forum 3 11-07-2009 11:27 PM
opinions on using chains for snow camping? beertinted TJ Wrangler Technical Forum 5 01-12-2007 11:55 AM
Lockers and Snow Chains? jeepboy21 YJ Wrangler Technical Forum 3 11-23-2006 07:40 PM
GoClaws snow/mud chains? remedy 66 TJ Wrangler Technical Forum 1 03-07-2006 04:59 AM
