Snapped a transmission mount bolt on T-Case skid plate - JeepForum.com
post #1 of 3 Old 04-05-2007, 10:52 PM Thread Starter
blueteej
While installing a transfer case drop I snapped one of the four transmission mounting bolts.
So ... now what?
Can it be driven like this?
How do I pull the broken bolt out and to replace it? The head cleanly snapped off.
Out of curiosity - and if you have a minute to read on, how critical was it to loosen these bolts when doing a TC drop? I bought a Skyjacker t-case drop kit (which I do not recommend) and their instructions don't mention loosening the four transmission bolts while dropping the t-case. The t-case drop written in 4x4xplor http://www.4x4xplor.com/t-casedrop.html states to loosen them first and then tighten them as a final step.
Who is right? After having it installed for about a week I went back into it tonight as strange thumping develop under my foot while driving - I could feel it hard when driving 30 or less over minor road bumps. Figured something had to be loose which is why I started checking everything tonight and snapped the bolt.
And while I'm on the topic of conflicting info ... Skyjacker says to torque their six skid plate bolts down to 75-80 ft lbs. Two of the six stripped before getting to this level. As they were around 55 to 60, I left them in until tonight. I pulled them and replaced them with grade 8 hex bolts and torqued them to 55 ft lb per 4x4xplor.com. Again, which is the right spec? 75 ft lbs or 55?
1997 Wrangler TJ, Blue/Saddle, Low Output 4-cyl, 5-spd, Dana 30/35, 4.10 axle, 2.5 OME coil and shock lift, RE Quick Disconnects, 245-75/16 Goodyear MT/Rs on Moabs and we call her Daisy.
blueteej is offline
post #2 of 3 Old 04-05-2007, 10:56 PM
Rocky529
Rocky529's Avatar
It is a good idea to loosen them before dropping the skid to lower the t-case. It will eliminate any stress on the transmission mount.
You should be ok with 3 bolts, but if you want to replace it, you are going to have to support the transmission and then drop your t-case skid plate to get to the mount.
Off the top of my head, 55-60 ft/lbs sounds about right for the t-case skid plate bolts.
The clunking you are experiencing is most likely your t-case linkage that is contorted since your t-case drop. To correct it, I suggest installing an Advance Adapters re-location bracket.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 3 Old 04-06-2007, 05:19 AM Thread Starter
blueteej
Thanks Rocky. Nice rig by the way.
Anyone else with an opinion on how critical this fourth bolt is and ways to replace it?
blueteej is offline
Snapped grade 5 skid plate bolt off vtx531 TJ Wrangler Technical Forum 42 10-07-2009 05:20 PM
Transfer Case skid plate Bolt/Nut STUCK!!! paine TJ Wrangler Technical Forum 8 01-17-2009 05:42 PM
Transmission to skid plate mount champelite210 YJ Wrangler Technical Forum 1 09-21-2008 04:10 PM
help. Snapped transmission mount to skid plate bolt! ClemsonJeepGC TJ Wrangler Technical Forum 15 04-23-2006 07:11 PM
weird bolt/mount on skid plate/tranny ?? evilpsych YJ Wrangler Technical Forum 5 11-11-2001 02:28 AM
