Quantcast Snap Ring/Retaining Ring Pliers SYE Install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Snap Ring/Retaining Ring Pliers SYE Install
Old 09-28-2004, 01:51 PM   #1
mking7
Okay, It seems pretty obvious from my search that I need a large set of snap ring or retaining ring pliers. Can anyone be more specific? What size or better yet a brand and a part number.
Jerry- I saw in an old thread that you had found just the right tool on a Snap On truck...any idea what that part number was???
Thanks guys.
2003 TJ and a bunch of crap bolted on........
mking7 is offline   Reply With Quote
Old 09-28-2004, 02:51 PM   #2
mking7
will this cover me?
http://www.sears.com/sr/javasr/product.do?BV_SessionID=@@@@2016549030.1096401042@ @@@&BV_EngineID=cclfadcmjgdlffhcehgcemgdffmdflk.0& vertical=TOOL&pid=00930359000
Old 09-28-2004, 03:46 PM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I never saw a snap-ring tool in Sears that would open widely enough to do this particular job. No idea what the p/n was for the tool I bought off the Snap-On truck but the rep knew exactly what I wanted when I said none of the other snap-ring pliers I had seen would open widely enough.
I think any of the tool trucks that service garages and dealers would have this particular tool.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 09-28-2004, 04:53 PM   #4
mking7
How far do they need to open?
Old 09-29-2004, 09:32 AM   #5
Kerndone
I lack money
Kerndone's Avatar
I used these and a cheapo snap ring pliers (didn't even have a spring loaded hinge) from sears. It was about 20 bucks for both of them. I don't know, but I didn't have a problem with the one snap ring or all of the lock rings I had to install/remove. I even told my dad to go inside cause I was about to get aggravated. About 1 minute later I had the last two on and I was all done with the lock ring part. I even had to take apart the t-case a second time, and this time I bet on the 2 lock rings I removed and replaced I spent all of 1 minute using those sears lock ring pliers in that link. Just open up the lock ring slightly larger than the diameter of the output shaft, start at the back and slide it all the way down to where it belongs. My first instinct was to open it wide enough to go around the output shaft, and that would have been a PITA. I am sure you won't be upset getting a good set of lock ring pliers, but if you only need 'em once, get the cheaper ones.
Red Jeep Club Member 111
'99 TJ - work in progress...see profile
'08 WK - Silver RME, DD.
Kerndone is offline   Reply With Quote
Old 09-29-2004, 10:05 AM   #6
Bucket110
i just fought with those for a day and the only advice i can give you is to get a heavy duty pair of snap ring pliers, a second set of hands and multiple screwdrivers. o and either a stiff drink or a case of beer for afterwards....I HATE SNAP RINGS!!!
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
[COLOR=blue]NEJEEPZ[/COLOR]
[URL=http://community.webshots.com/user/2k2blktj]My Jeep[/URL]
Bucket110 is offline   Reply With Quote
Old 09-29-2004, 11:15 AM   #7
mking7
Thanks a lot.
Old 09-29-2004, 11:55 AM   #8
Poppy360
How did the SYE install eventually go? Get your problem fixed? (I'm going to be tackling this in a few weeks.)
'98 TJ Sport 4.0L
RE 3.5" Long Arm w/ 1"BL; 35" KM2's; 8.8; HP30; 4.88's; Dual ARB's; Warn HS9500i; OME Shocks; CO2; Fully Armored; ORO U-Turn Steering; LoD Rear Bumper/Tire Carrier; Durango Steering Box; Heated Seats
Poppy360 is offline   Reply With Quote
Glock Forum
