Quantcast Snap Ring Pliers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Snap Ring Pliers
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 12-08-2009, 10:57 PM   #1
Mayfair_Jeeper
Jack *** of All Trades
Mayfair_Jeeper's Avatar
Snap Ring Pliers
Im getting ready to do my SYE in the next few weeks, and want to know what snapring pliars I should get...since this is probably the only time I am going to use them, i want a set that will get the job done without me cursing, but I dont need snap on quality.....thanks
"Built not Bought" club member #14
"Survivalist Jeep Club member #54
Mayfair_Jeeper is offline   Reply With Quote
Old 12-08-2009, 11:04 PM   #2
LGriffith
I went and bought some nice snap ring pliers with 3 change-able heads but they didnt open wide enough so they were basically useless. Most of the rings on there were I believe "lock rings" not "snap rings" anyway. The kind without the two little holes, but with the diagonal edge. I would look into getting a set of lock ring pliers instead. I ended up having to drill two little holes to let snap ring pliers work, than borrowing some that opened wide enough. :
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote
Old 12-08-2009, 11:27 PM   #3
crqflier
I had no use for snap ring pliers doing the SYE on my '99. The only snap ring with holes I saw was holding in the bearing on the rear cap. You don't need to remove that. Could be different on your '06, but i doubt it. You only need lock ring pliers. Sears for $11. Works great.
crqflier is offline   Reply With Quote
Old 12-08-2009, 11:30 PM   #4
Mean Max
Mean Max's Avatar
I bought these, and they work fine.
Harbor Freight Tools
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Mean Max is setting up his Jeep shop!
Picture history of my progress here.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Old 12-09-2009, 01:03 AM   #5
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The key thing to keep in mind is that for a SYE installation, it needs to be able to open far wider than a standard, even a "heavy-duty", snap ring plier does. None of my local stores carried anything that opened widely enough so I ended up buying mine on one of the tool trucks stopped at an automotive dealership. I think it was a Matco tool truck but it could have been a Snap-On, Mac, etc. tool truck.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Glock Forum
