small white plug under front dash cover - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > small white plug under front dash cover
Engo winches available at www.rockridge4wd.com! Free shippDan's Old as Dirt Birthday Sale!Advance Adapters SYE Kits
Unread 05-01-2014, 11:05 PM   #1
bigwave
bigwave's Avatar
What is the small white flat plug under the front dash plate on a 2004 Jeep wrangler? it is on and faces to the right, white, and flat four or five wires.
bigwave is offline   Reply With Quote
Unread 05-02-2014, 01:37 AM   #2
Necko2529
Its for auto dimming, temp/compass mirror.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
[B]RIP "Prescott 19"[/B] Prescott Fire Department
Necko2529 is offline   Reply With Quote
Unread 05-02-2014, 08:54 AM   #3
robncar
We Got The Cup, AGAIN!!!
robncar's Avatar
Yep, your harness is pre-wired; not all are - mine was not. All you'd need is the mirror, the upper harness (runs up the passenger A pillar), and a second ambient temperature sensor at the front grill (also pre-wired, just add the sensor).
Here's more:
C203 Mystery - Auto Dim/Temp/Compass Mirror Install
Pre-Wired - Auto Dim/Temp/Compass Mirror Install
Without the pre-wire it's a pain, with it, it's plug and play.
robncar is offline   Reply With Quote
Unread 05-02-2014, 09:16 AM   #4
Necko2529
Here's more:
Really? I thought all of them came pre-wired. I bet its a pain. Did you install one yourself? I know I like mine, mainly for the map lights since there's no visor/mirror lights.
Unread 05-02-2014, 09:34 AM   #5
robncar
robncar's Avatar
Yep, that first link in my prior post "C203 Mystery" details the fun I had. But, in the end, the painful memories fade and the enjoyment continues on. Likely, that's how the ladies deal with childbirth too...
Unread 05-02-2014, 09:38 AM   #6
Necko2529
It must be, especially for ones with more than one... Mine had thee, i give her kudos and tell her she's a bigger man than I!!
Unread 05-02-2014, 09:52 AM   #7
irnmadn88
Best thing about that harness, it has a 12v wire (green/white or white/green) that is easily tapped for the Reverse feed for the auxiliary/reverse lights using a SPDT switch.
Colorado Jeep Club Member #667
irnmadn88 is online now   Reply With Quote
Unread 05-02-2014, 03:37 PM   #8
bigwave
bigwave's Avatar
I was hoping that's what it was.
That is awesome, I was wanting to add the mirror with the built in compass, that is perfect, now does any one know where I can get one at best deal.
Unread 05-02-2014, 08:09 PM   #9
robncar
robncar's Avatar
1) Mirror, Inside 55156197AA ~$350 - New (Best to find used)
2) Bracket Ambient 56047123AB - (Discontinued, find used)
3) Sensor Ambient 56042395 ~$12 - New
4) Wiring, Mirror 56047087AC ~$30 - New
In complete kit form: http://www.jeepsareus.com/p/lv23.html
I bought my mirror used from a guy that was parting out.
Unread 05-02-2014, 10:16 PM   #10
geroux
I bought a complete factory kit around '06 with mirror, sensor and bracket. Can't remember where from. Plugged right in.
Here's a writeup...
http://www.wanderingtrail.com/Mods/T...lec_Mirror.htm
geroux is online now   Reply With Quote
Unread 05-02-2014, 11:02 PM   #11
geroux
Just realized I posted redundant information. Tried to delete.
Unread 05-03-2014, 07:32 AM   #12
robncar
robncar's Avatar
Yeah...
...but we don't take your word for anything. You're not a supporting member, have not posted enough to establish any credibility or filled out your profile correctly so apparently that makes you an idiot. So you've been told.
Unread 05-03-2014, 07:37 AM   #13
Necko2529
Yeah...
Unread 05-03-2014, 09:52 PM   #14
geroux
Yeah...
Hey genius'. I was just trying to be helpful. Posted information and then realized the same information had been provided. Concurring with information of previous post's is something that has been done numerous times before.
I removed my sarcastic signature so stop being immature *******s.
Unread 05-04-2014, 09:38 AM   #15
robncar
robncar's Avatar
It was a joke bro... only a joke. I remember the threads that resulted in the generation of your now former signature. Perhaps a tad down on the sensitivity meter?
And, as to the genius comment, yep... Mensa member. I used to be in the top 2% nationally but that's likely declined over the years. Probably wouldn't make it in today.
