small lift suggestions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > small lift suggestions
4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededBead Lock Wheels! Raceline, Trail Ready, & Trail-GearJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 09-27-2007, 07:00 PM   #1
RON310
Other than the OME lift, any other recommendations on a lift in the 2 - 3" range?
I had the OME lift on my previous jeep but want to see if there are any opinions on something else in that size.
Also, instead of the trackbar relocation bracket, is it better to get an adjustable trackbar, or no difference really, other than some drilling?
I want to lift my new jeep in the 2- 3" range, and want to make sure i cover all the bases before i start spending.
RON310 is offline   Reply With Quote
Unread 09-27-2007, 07:07 PM   #2
bman9089
You get what you pay for
bman9089's Avatar
First off, take a look at BDS. To my knowledge, they're the only other MFG that have a lift in that size, and that have a good rep. around here.
As for the adj. t-bar, I say go for it. The bracket is made for a certain height. As in, to keep your tires aligned side to side in the rear, you'll need to get the exact lift that the bracket is made for. So, if you buy a 2" lift, and something were to happen where you end up getting too much (2.5") or too little (1.5"), your results may not be very good. It may not be noticeable, and probably isn't most of the time, but the tires may still be off because the bracket is a one size fits kind of thing. The adjustable bar will allow you to adjust it no matter how much you lift or how much you settle, and will be necessary later on if you go higher or add spacers for adtional lift or to fix the rake of the jeep.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Unread 09-27-2007, 07:12 PM   #3
TJAB
Full Traction makes a good 3" lift that sells for a good price and is quite complete.
TJAB is offline   Reply With Quote
Unread 09-27-2007, 08:45 PM   #4
bman9089
bman9089's Avatar
Also Ron310,
Decide now just what size tire you want to run. If 32s, get 2-3" suspension. If 33s, get 3-4". Choose the latter (example: 4" for 33s) if you want good offroad articulation.
But you'll get a lot of suggestions and really won't be able to nail down exactly what you want unless you can tell everyone what height you are aiming for.
Vague questions will grant you vague replies.
