Slow to start after lift, Speedo gear? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Slow to start after lift, Speedo gear?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! RCV Axles at CCOR
Unread 05-18-2015, 01:45 AM   #1
Mousejockey
Since I did the lift/tires a few weeks ago, its been getting slower and slower to start. Before the lift it would start right away. I have not changed the spedo gear yet, being electronic does the computer figure in the spedo reading into all the other crap when it figures what fuel ratio, timing, ect?
Mousejockey is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 01:50 AM   #2
Neil F.
Speedo has nothing to do with starting ir running
Neil F. is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 01:50 AM   #3
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you had the battery load tested after knowing that it has a full charge?...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 05:08 AM   #4
Athensdawgs81
Yeah, sounds like your lift may just be coincidence to your battery going bad.
Athensdawgs81 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 07:39 AM   #5
Mousejockey
Battery is fine, its not slow turning over, used to catch very quickly once you turn the key. now its turning over several times before its starting.
Unread 05-18-2015, 08:26 AM   #6
Athensdawgs81
I still don't think it's related to your lift. Do you have any codes? Are the plugs good? Are you getting ample fuel? Maybe the anti-drainback valve. Maybe the CPS starting to go. At this point until you do some troubleshooting it could be anything.
Unread 05-18-2015, 08:32 AM   #7
mdm
Farm Wheeler
Originally Posted by Athensdawgs81 View Post
...Maybe the anti-drainback valve. ..
Turn the key on and let it sit for a few seconds before cranking. If this helps it start quicker it could be the anti-drain back valve in the fuel pump. It could also be a leaking fuel injector.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 12:51 PM   #8
Mousejockey
I'll check into all that, was just wondering is the electric spedo was a factor.
Unread 05-19-2015, 06:58 AM   #9
JBTJ
You don't have one. Your speedometer runs off a small gear located inside the transfer case. The gear, is about $40 and takes less than 5 minutes to change.
But this has nothing to do with the starting issue, only with your speedometer being off due to the larger tires installed.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 10:40 PM   #10
Mousejockey
Hmmm let the jeep sit for a day after the wheelin trip, several times on the trip had long cranks before it would fire, wen out tonite and hit the fuel Schrader valve and nothing came out. Turned the key on for about 5 sec then cranked it and it fired right up. Let it run for a min, shut it down then poked the Schrader again and no fuel came out. Drainback valve?
Unread Yesterday, 08:27 AM   #11
biffgnar
biffgnar's Avatar
Which gets converted to an electronic signal for transmission to the PCM. Problem with that conversion or transmission while not common is possible.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 08:27 AM   #12
biffgnar
biffgnar's Avatar
Drainback valve?
Sounds like it
