Slow Going Build - JeepForum.com
post #1 of 10 Old 05-13-2010, 08:09 PM Thread Starter
antec
Slow Going Build
ok i thought i should start a build thread so i can keep track of what all i'm doing and keep every one up to date.
as the jeep sits now i have a
2.5l, ax-5, stock np231, D30/Ford8.8.
3" full traction
31" tread right MTG
Sorry no pictures today but i will post some up as soon as i can.
Right now i'm saving up for a 5.9l and 46RE.
plans are to swap out the motor and trans first.(my parts will be coming from BackWoodsOffroad) after that then some lockers front and rear with some
35's and a home made long arm. i will have my welder do the welding
i will then build a new roll cage and tie it in to the frame(thinking 6 point)
i would like any info or advice anyone can give i only want to do this ones
antec is offline
post #2 of 10 Old 05-17-2010, 01:13 AM
wushaw
Rockin jeep
wushaw's Avatar
Learn how to weld, take your time, enjoy your build, drink plenty o beer.
wushaw is offline
post #3 of 10 Old 05-17-2010, 08:26 AM Thread Starter
antec
Thanks i have a welder that i use for a lot of things. I used him for my 8.8 mounts and almost evey weld on my YJ.I dont trust my weld on motor mounts
well i got a little up-date i found my motor yesterday. only has 45,000 on it. i got every thing i could get off of it. every bit of wire the Y-Pipe, hoses, intake tubes, ECM.
so here is a list of all my parts i know i will need as of now plus some starting prices
Motor 5.9 $621
Motor Mounts $155
Radiator $320
23 spline input shaft $170
Electric Fan $320
Wire Harness(Built by Backwoods But i might try it my self) $700
AT Shifter kit(I have a Stick Right now) $300
pictures still to come as soon as i get a new camera
antec is offline
post #4 of 10 Old 05-17-2010, 08:53 AM
MO2500
You don't trust your welds for motor mounts but do trust them to keep the axle under your jeep? Not flaming you, just sounds a little contradictory
Could be wrong, but i believe there would be greater forces on the axle mounts than there would be on the engine mounts. As long as you have a welder thats up to the task, take your time to prep the metal well, and make sure you get good penetration I wouldn't be worried about doing the welding yourself assuming your 8.8 is holding up just fine
Instagram: @omsmike
MO2500 is offline
post #5 of 10 Old 05-17-2010, 08:56 AM Thread Starter
antec
i must have misworded what i said
what i ment to say was he welded my rear end and every weld on my YJ lol
and that i dont trust my weld
antec is offline
post #6 of 10 Old 05-17-2010, 09:02 AM
MO2500
I thought it was strange when you referred to your welder as a "him"
Instagram: @omsmike
MO2500 is offline
post #7 of 10 Old 05-17-2010, 09:04 AM Thread Starter
antec
Thats going to have me laughing all day
antec is offline
post #8 of 10 Old 05-25-2010, 06:44 PM Thread Starter
antec
ok so I was just thinking. I can't see spending $700 on someone to do something I can do.
but I need to know what all wires need to be swapped. is there a Wright up or anything that I'm not finding
antec is offline
post #9 of 10 Old 05-28-2010, 04:56 PM Thread Starter
antec
Ok well my camera broke on me so I took the wife’s video camera and just shot a short video of the motor I will get a new camera before the swap so I can document it.
YouTube - 5.9 v8 for my jeep tj
antec is offline
post #10 of 10 Old 09-14-2010, 02:54 PM Thread Starter
antec
ok well a small update here i just got my 35x12.50 km2's(pic soon) on thay look good and run great.
have one hold up on the motor swap i cant find a good 46re in the junk yards around here. so i have been keeping an eye out will keep giving update as thing go on.
antec is offline
Beginning of a slow pain noob build. Thoughts? ChrisTJCO TJ Wrangler Technical Forum 17 05-07-2010 10:51 AM
settled on my 1st extremely slow build plan CreepyCrawler95 YJ Wrangler Technical Forum 4 02-02-2010 07:24 AM
Slow Mo TJ - Build mferrari TJ Wrangler Technical Forum 198 12-30-2009 11:05 PM
My 97 SLOW build up! mudking_ky87 TJ Wrangler Technical Forum 31 08-23-2009 07:08 PM
Oil pressure slow to build when starting 01TJDriver TJ Wrangler Technical Forum 11 02-21-2008 10:19 AM
