Quantcast slips out of second gear - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > slips out of second gear
Old 03-15-2009, 08:46 PM   #1
toneloc3131
does anyone know why my jeep slips out of second gear when its not warmed up. also its tough to get it into second gear for the rest of the ride. have to feel it go in to prevent grinding
toneloc3131 is offline   Reply With Quote
Old 03-15-2009, 08:54 PM   #2
Rocky529
Jeep
Rocky529's Avatar
Worn synchronizer
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 03-15-2009, 09:25 PM   #3
toneloc3131
is that part of the clutch or transfer case and how can i check or replace it? i read that it could also be the transmission is loose on clutch housing.
Old 03-15-2009, 09:46 PM   #4
bctj
Do you have a body lift?
bctj is offline   Reply With Quote
Old 03-15-2009, 09:49 PM   #5
Rocky529
Jeep
Rocky529's Avatar
How many miles on your YJ?
You shouldn't technically be posting on the TJ forum.
The synchro is internal in the transmission.
Old 03-15-2009, 10:00 PM   #6
toneloc3131
sorry i didnt realize this was the tj forum. new to the website. but i have a 4 inch rough country lift with 71,000 original miles
Old 03-15-2009, 10:03 PM   #7
ET48
It is either your:
synchronizer gear in the transmission
shifter boot or floor plate preventing from full engagement into 2nd gear
Or you need to change your tranny oil, (may help)
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline   Reply With Quote
Old 03-15-2009, 10:11 PM   #8
toneloc3131
it actually feels like the shifter boot is in the way. what can i do about that? can i replace the tranny fluid myself?
Glock Forum
