Slips out of 2nd, 4th, and reverse
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I put a 3" suspension left on my 2003 Wrangler. Since then I keep slipping out of 2nd, 4th, and mainly reverse. I took the boot off of the shifter and it shifts much easier and with no trouble slipping out of gear. IT seems like the rubber is pulling back the shifter and making it slip out. Do I need a new design for the boot or is there another way to correct the problem. I was reading a thread about another boot on a YJ that can be adjusted, but wanted to know if that is a similar soultion for a 2003 Wrangler. Thanks for any help.
#2 |
Jeep
Look at the ring around the shifter, raise it one inch and that will raise your boot one inch thus preventing it from being so short and binding in the downward gears. This is happening because you dropped your t-case.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#3 | |
[FONT="Impact"][SIZE="4"][B][COLOR="Red"]DIRT BAG[/COLOR][/B][/SIZE][/FONT] |
#4 |
How did you move the console back? And to the other help, moving the ring didn't help. It keeps pulling the shifter away. thanks
#5 |
#6 |
#7 |
#8 |
There is also a foam piece on the shifter. You can cut that off and it should help. Also, the rubber boot is directional, so if you have it on backwards, it will pull like that.
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies. |
#9 | |
#10 | |
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
