Which Slip Yoke Eliminator (SYE) do you recommend for a 3.5" Short Arm Lift? - Page 2 - JeepForum.com
post #16 of 22 Old 07-15-2010, 08:35 PM
roundlitefan
roundlitefan's Avatar
What noone is mentioning is a 1" MML. They are inexpensive (about $60 if you buy the JKS one that uses the factory motor mounts) and if your vibes are very minimal it should help ease the rear driveline angle enough to help you out. I think Teraflex makes a 5/8" one of that style as well.
Running a MML and a TC drop together certainly isn't ideal, but it can fix you up until you can save the money to get a SYE/rear driveshaft/adjustable UCA's and do it properly.
roundlitefan is offline
post #17 of 22 Old 07-15-2010, 11:00 PM
TheRealSICNICK
Originally Posted by Richd1963 View Post
OK, so is this too good to be true?
Rubicon Express RE1895-255 - Rubicon Express Rear CV Driveshaft for 04-06 Jeep® Wrangler Unlimited Rubicon with Short Arm Suspension Lift - Quadratec
I was cruising and looking for the necessary stuff I am going to need and I stumbled onto this and had to put it out here and ask. What do you think?
Correct me if im wrong but is for a "RUBICON MODEL ONLY"
Dosent the rubicon come stock with an sye and cv style rear driveshaft?? So this would not work with the 231 tranfer case, right??
TheRealSICNICK is offline
post #18 of 22 Old 07-16-2010, 05:05 AM Thread Starter
Richd1963
Richd1963's Avatar
I knew I had to be missing something. Thanks for helping me see the light.
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
post #19 of 22 Old 07-16-2010, 06:24 AM
timmytimm3
This thread will explain everything:
http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
timmytimm3 is offline
post #20 of 22 Old 07-16-2010, 04:20 PM
biffgnar
biffgnar's Avatar
Rubicon does come with a fixed output so does not need a SYE but Rubicon does not come with a CV driveshaft. Since this is for a Rubicon it is probably set up for the fixed output of a 241.
biffgnar is online now
post #21 of 22 Old 07-16-2010, 11:33 PM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
Here's a list of parts you need to do the SYE/CV rear driveshaft modification (not necessarily these exact brands, but since you've got RE parts anyway). If you shop around, you might find these parts cheaper, and there's other companies that make these too (like the adjustable upper control arms).
Adjustable rear upper control arms (so you can adjust your rear pinion angle when you install the SYE and CV driveshaft)
http://www.rubiconexpress.com/jeep/ZJ/Product.aspx?part=RE3783
Rear track bar bracket to compensate for the rotated rear axle. Do you also have an adjustable rear trackbar? If not, you might need one to center your rear axle.
http://www.rubiconexpress.com/Products/Default.aspx?part=RE1602
AA SYE and CV rear drive shaft (can also be ordered directly from Tom Wood's company - might be cheaper). Definitely shop around here; some places want to charge you more for just the rear CV driveshaft than for this complete combo.
http://www.4x4groupbuy.com/store/advance-adapters-slip-yoke-eliminator-kit-tw-drive-shaft-p-115.html
You might also need to buy a pair of rear shock relocator brackets that mount on the axle after you rotate your axle for the SYE/CV driveshaft. This is what I put on mine:
TeraFlex Rear Shock Mount Relocators, TJ, 1997-06
armyRN is offline
post #22 of 22 Old 07-21-2010, 05:37 AM Thread Starter
Richd1963
Richd1963's Avatar
Thanks so much armyRN, Yep thats what I gotta do.
slip yoke eliminator , sye , sye kit
4" RC lift questions. slip yoke eliminator? CV drive shaft? shocks? wrangler10 TJ Wrangler Technical Forum 16 05-30-2010 05:42 PM
Slip Yoke Eliminator, Do I need it? barhall YJ Wrangler Technical Forum 10 02-22-2009 08:24 PM
Slip Yoke Eliminator 97MilitaryTJ TJ Wrangler Technical Forum 10 01-12-2008 05:06 AM
Slip Yoke Eliminator vs Motor Mount Lift?? JPASELL TJ Wrangler Technical Forum 22 02-14-2007 02:58 PM
slip yoke eliminator? Tonka YJ Wrangler Technical Forum 11 03-20-2001 09:24 PM
