Slip yoke eliminator - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Slip yoke eliminator
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-02-2015, 09:03 AM   #1
7179CJ5
1979 CJ5
How many out there have installed a SYE kit with new DS with a 4"lift?
Getting all kinds of suggestions locally,!want to see what the majority is doing.
Thank you in advance!
7179CJ5 is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 10:07 AM   #2
WhiteMtnJeep
It Should Have Been MEG!!
WhiteMtnJeep's Avatar
Some install the TC drop kit to lower the transfer case 1". Some do this in conjunction with a MML. While it will make the driveline angles better it also will reduce you clearance by an inch.
The best way is with a SYE and proper driveshaft (you can't do the SYE only). The SYE/driveshaft will allow you to keep your full clearance with the new lift and, IMHO, is the better way to go.
Whichever route you choose make sure to check and adjust you pinion angles afterwards.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Polyphase Meterman IBEW Local 387
Work with enthusiasm as though you were working for the Lord rather than for man.
http://www.treadlightly.org/
Siena Jeep Owner's Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
WhiteMtnJeep is online now   Reply With Quote Quick reply to this message
Unread 08-02-2015, 10:24 AM   #3
7179CJ5
1979 CJ5
How would you correct the pinion angles if they are not right?
Unread 08-02-2015, 10:43 AM   #4
jjvw
jjvw's Avatar
Adjustable control arms to rotate the axle. ~3" of lift seems to be about the spot where a SYE becomes needed. This is accompanied by a double cardan drive shaft in the rear. Can you remind us if you have a TJ or an LJ?
'03 Rubicon
jjvw is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 11:21 AM   #5
7179CJ5
1979 CJ5
Thank you for the information.
SYE/kit has already been ordered from Novak.
However, we were informed that measurements would be needed in to order the DS. But I think i put the cart before the horse, have put my lift on yet.
What vendor do you represent?
Unread 08-02-2015, 11:56 AM   #6
jjvw
jjvw's Avatar
None. I'm just a guy doing a whole bunch of laundry on the weekend.
'03 Rubicon
Unread 08-02-2015, 12:06 PM   #7
4wheelrampage
You will see some driveshafts premade. Tattons is one company that does this and who I went with one time. However the official and correct way to measure for driveshaft is install your lift and sye then measure and order. My last shaft I ordered from Tom Woods with my exact measurements after I installed the sye. Takes 1 buisness day to build, then it can be overnighted
[quote=ApolloXIII]
Tasting a drop isnt going to kill you.
And what doesnt kill you makes you stronger.
Therefore, tasting a drop of antifreeze actually makes you stronger :)
[/quote]
Mac users : control+option+command+8
4wheelrampage is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 12:33 PM   #8
jdub2k5
the rugged ridge sye got installed on mine when I did a 4.5 bds lift. I have no wobbles like my last jeep.
2004 TJ 4.0 5 speed, 2 inch body lift, barricade armor, 4.5 bds lift, 35 mtz, sye, and tons more
jdub2k5 is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 12:37 PM   #9
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
If you plan on a belly up I would recommend a super short SYE.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 12:55 PM   #10
4wheelrampage
Wobbles are not related to a sye OR driveshaft. If they were unbalanced you would have vibrations, but no wobble. You probably cured your death wobble by replacing your control arms/bushings.
[quote=ApolloXIII]
[/quote]
Unread 08-02-2015, 01:09 PM   #11
7179CJ5
1979 CJ5
Sorry, I failed to mention I have an LJ which I know helps with a lift given the DS is a little longer.
Unread 08-03-2015, 04:51 PM   #12
4wheelrampage
The correct solution for any jeep to be lifted is sye, double cardon shaft (custom ordered, no more expensive then prefab), and adjustable upper control arms. Anything less then that and you may or may not have vibes. The higher you go with out the previous parts the more likely you are to get vibrations. We wouldn't be able to definitively say that at X" of lift you will begin to experience undesired performance.
[quote=ApolloXIII]
[/quote]
Unread 08-03-2015, 08:54 PM   #13
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Maybe I missed it but what size tires are you using? With a 4" suspension lift its recommended to have upper and lower adjustable control arms installed for the rear axle so that you can center the wheel in the wheel well when articulating/flexing the suspension, especially if you have 35" tires.
Some will state that fixed control arms (not adjustable) will work just fine. What you have to keep in mind is that all TJ/LJ Jeep configurations are different, they're not exactly blue print matching and that's where the ability to make adjustments becomes important. Adjustable control arms will allow you to make adjustments as you progress through your modifications as you build your jeep to fit your needs.
I've been using Tom Wood http://www.4xshaft.com/ for many years and have always been satisfied with his products, with one phone call he can most likely fill your needs for your driveshaft... HTH
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 08-03-2015, 11:16 PM   #14
geroux
Upper and lower adjustable control arms aren't necessary. If you have fixed lowers that are of adequate length adjustable uppers can dial in the pinion.
I have a 4.5" lift with a double cardon driveshaft and fixed (not stock)lowers. Pinion angle is just fine using just the uppers to adjust.
geroux is offline   Reply With Quote Quick reply to this message
Unread 08-03-2015, 11:33 PM   #15
Da-Tinman
You'll end up ordering a DS. I just added SYE and double cardon shaft to my LJ and the shaft length you need is not in stock anywhere (at least it wasn't a month or so ago). http://www.4xshaft.com/ built the correct shaft for me cheaper than an off the shelf shaft would have been if they were available. Pretty damn quickly too!
With 5" lift and a tummy tuck my shaft measured 26.5"
You will also need rear spring bucket correctors. http://www.jeepinoutfitters.com/prod...rection-plates
Pointing the pinion at the transfer case will put the springs in a weird position without them and I doubt they'll stay in place. I got lucky and got a used set off EvilBay for 50 bux shipped.
I have a long arm kit so adjusting the pinion was fairly easy.
Watch your rear track locator bracket for fuel tank clearance, the stock one may get real close when you rotate the rear for the proper pinion angle.
NO vibrations. It was awful before, starting at 30 mph all the way to 65.
Just Another Masochistic Jeep Owner.
Da-Tinman is offline   Reply With Quote Quick reply to this message
