Slight shimmy at 55 to 65 - JeepForum.com
 2Likes
post #1 of 27 Old 09-19-2017, 08:29 PM Thread Starter
Kristian_Burns
I just got new 31 inch general AT2's put on my jeep and now it has a slight wobble at high way speeds unless i accelerate passed 65. Pep boys put the tires on the stock steel rims, balanced them and did an alignment. Now I took the jeep back today to get them balanced again to see if this solves the problem. After driving home the wobble is still there and he is assuring me that they are balanced and if i have anymore wobbles it is not because of my tires. Should i go to another shop to see if they are actually balanced good or should i be checking other suspension components?
Kristian_Burns is online now
post #2 of 27 Old 09-19-2017, 08:52 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you done a dry steering test?...
Knuckelhead is offline
post #3 of 27 Old 09-19-2017, 09:07 PM Thread Starter
Kristian_Burns
Please enlighten me on this
post #4 of 27 Old 09-19-2017, 09:12 PM
biffgnar
biffgnar's Avatar
Get them rebalanced and watch over the guys shoulder. Close is not close enough.
TheBoogieman likes this.
biffgnar is offline
post #5 of 27 Old 09-19-2017, 09:17 PM Thread Starter
Kristian_Burns
I don't think they would let me do that. trust me i would.
post #6 of 27 Old 09-19-2017, 09:24 PM
biffgnar
biffgnar's Avatar
I'd go to a different shop then. I have some guys down the street with a Hunter machine who have no problem with me watching over their shoulder. There have to be more shops like that. Either that our you have to raise hell with them in the waiting room that they have to be exact. They are too prone to take the easy way out.
biffgnar is offline
post #7 of 27 Old 09-19-2017, 09:38 PM
Shark_13
Make sure you are not over inflated, as many tire shops tend to do. Make sure toe in is good. And as noted above, perfect balance.
Do a dry steer test and check all the tie rod ends up front, check your ball joints and unit bearings. Both ends of track bar. Control arm bushings too.
Shark_13 is online now
post #8 of 27 Old 09-19-2017, 09:38 PM
Knuckelhead
AFSOC Retired
With the engine off have someone turn the steering wheel back and forth a few inchs while you watch the steering linkage and the parts attached to it.
Your looking for slop where it shouldn't be...
post #9 of 27 Old 09-19-2017, 09:52 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Listen to biffgnar. It's a balance issue. I had a shimmy between 45-50 mph. The tire shop I bought my 35's from balanced them 3 times before I took it somewhere else to get it done right.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #10 of 27 Old 09-19-2017, 10:14 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's a tire balance problem no matter what that shop is claiming.
arg0413 likes this.
Jerry Bransford is offline
post #11 of 27 Old 09-20-2017, 06:24 AM
NotURMailman
NotURMailman's Avatar
Listen to what you're being told here and don't listen to what PB is telling you.
Speed related wobbles, shakes, and shimmies are almost always tire related.
In your case it started after doing nothing more than getting new tires, that makes it even more likely.
Take them to a shop with a road force machine and have them balanced properly.
Then, (after you drive it and see that the problem is gone) take the receipt for that back to PB and tell them you want the money back that they charged you for "balancing" them.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #12 of 27 Old 09-20-2017, 07:14 AM
1longcj
Ask them to rotate front to back, and take it for a test drive. If it goes away or changes, tell them to rebalance the back ones.
I would mark the tires to verify they actually rotated them.
1longcj is offline
post #13 of 27 Old 09-20-2017, 08:38 AM Thread Starter
Kristian_Burns
What pressure should i run those at? They are 31 in, General AT2, 10.5 i was thinking 30 psi. Is that good? I will do the dry test tonight
post #14 of 27 Old 09-20-2017, 08:40 AM
NotURMailman
You'll probably be better off in the 26-28psic range.
post #15 of 27 Old 09-20-2017, 08:52 AM
Shark_13
28 cold would be a good starting point, pressure increases as the tires warm up from driving.
What did the tire shop set them to?
