#1 | |
Sliders Needed, Cheap & Fast
I need to get sliders for my TJ before I go to Big Bear for the 4th. I really like the Custom 4x4 ones. Anybody have set they don’t use any more, or another suggestion? Please call or e-mail Moose. 619-200-6034, 858-549-9550, moose_daddy@hotmail.com. Thanks, guys.
Happy Trails, Moose ![]()
#2 |
JF is my second home.
Cheap and sliders do not work in the same sentence, most here say A to Z fabrication or Rokmen, you pick. If you are going to use them the way you should you shouldn't go cheap unless you like repairing your tub.
Max 2003 Jeep Wrangler Rubicon 4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs. TJ Tech Boot Camp TJ Specs "Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track" |
#3 |
rent a welder
buy metal ???? profit i just cruised craigslist forever until i found a cheap set. |
#4 |
RE: Sliders
OK... Point taken about cheap. I Mean Inexpensive...
I have a welder, can buy metal. have no space, or spare time to do it in. |
#5 |
How much is cheap? I went with Smittybilt XRC's $230, they'll do the trick... I think those others are nice, but not much better than the XRC's, sure ww2ww, but they don't really provide that much more under body protection.
#6 |
I personally love my warns, was on a guard rail (dont ask) and all that happened was I had to fix the paint on the rock rails. The guard rail lost bad.
#7 |
Go here, http://store.4wheelingplus.com/products.asp?cat=149 Enjoy. I've got the 99.00 set. They have seen rocks , my tub is still intact, no dents. will be welding bar across next cause I already have a bar so why spend more cash?
Sienna Jeep Club: Member #2 ___ ___ [l_,[____], l---L - OllllllO- ( )_) ( )_)--)_) |
#8 | |
Cheers, Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors |
#9 |
warn rock sliders. like $250
1998 Jeep Wrangler 2.5L Turbo @8psi (haltech) Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 2.5" RC Lift with 1.25" BL & MML on 33s TSL Boggers with Beadlocks. Ironman 9500 Winch, ARB Snorkel, Warn Bumpers/rock sliders/gas tank skidplates.. Smittybilt Tube Fenders, Axle tube seals, braided brake lines etc. |
#10 |
Demonic Jeep Freak!
Cheap sliders is an oxymoron like boneless ribs.
#11 |
here are mine, i am also gonna ad a "bar/step" in the future to make it easier to climb into
not the best looking, but much, much cheaper than store bought http://www.offroadjunkies.net/index.php?topic=347.msg2235#msg2235 |
#12 |
Shrockworks... Check them out.
My build thread: http://www.jeepforum.com/forum/f9/rubiconrazorbac-build-thread-792423/ |
#13 |
If you're looking for inexpensive and fast I'd suggest the Warn, too. They've been holding up nicely for my use the last 4 years (including several drops onto the sliders) and are good for what they are.
But if you're in a hurry, the other reason to recommend the Warns is that they're a mass produced item and probably stocked by several 4x4 vendors or local 4x4 shops. So having a set order and shipped out can probably be done quickly. If you go with some custom shops, sure the quality and durability is great but how quickly can they get them out the door and into the shipping pipe line. Maybe they can send out a set fast, in that case great. But if they get to you late they won't do you much good. Something to consider as you call around.
- Jay |
#14 | |
Big Bear, Here I come
Happy Trails, Moose |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
