sleeve currie arms to make them long arms? - JeepForum.com
post #1 of 33 Old 08-29-2010, 05:40 PM Thread Starter
bmxrules39
Ok so an idea popped into my head the other day while looking at my jeep and dreaming about a long arm setup.
I'm thinking I could cut my currie arms and sleeve them with a longer section of DOM tubing and weld the joint to one end and the threaded section to the other end, so I can thread the adjustable end back in, and I'd have long arms.
This would save me a ton of money, and I think it could be done and look really nice you can get DOM tubing with a .25 wall and a 1.25 ID so the original currie arms would fit nice and tight.
Also I'm thinking I would need to weld a nut to the end of the adjustable side so the jam nut has something nice and flat to tighten against
I just can't see why this might be a bad idea, but it seems like kind of a stretch, so I'm asking for some input.
§wHitt§
bmxrules39 is offline
post #2 of 33 Old 08-29-2010, 05:45 PM Thread Starter
bmxrules39
One more thing; I thought about selling my short arm lower curries, but from what it would cost to get all new joints, brackets, DOM tubing, and the $25 a piece threaded nuts- I really wouldn't make enough to come close to what it would cost
§wHitt§
post #3 of 33 Old 08-29-2010, 05:59 PM
Benderff
Benderff's Avatar
What about picking up some overtime, selling your currie arms and then building it right the first time?
Benderff is offline
post #4 of 33 Old 08-29-2010, 06:02 PM Thread Starter
bmxrules39
i just love how some people race to be the first to make a snide comment on any thread that's posted, if you don't have any input or real reason why this way is a bad idea then why do you feel like you have to post something?
§wHitt§
post #5 of 33 Old 08-29-2010, 06:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not sure why you want long arms, but the flaw in your theory is that one who is well versed in suspension design would know that the larger 1.25" shanks for use in lower arms are vastly preferred.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #6 of 33 Old 08-29-2010, 06:05 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I just love how some folks race to come up with ****amamie ideas to save a few pennies and can't wait to post it without thinking it through. Does that bother you as well?
I am Savvy
mrblaine is offline
post #7 of 33 Old 08-29-2010, 06:07 PM
Imped
Imped's Avatar
Not a terrible idea. So why do you "dream" of long arms?
OlllllllO
IndyORV
Imped is offline
post #8 of 33 Old 08-29-2010, 06:15 PM
Benderff
Benderff's Avatar
It's an internet forum. You wanted input about your lame idea, and I gave you some. If my idea of spending a couple extra dollars and doing it right the first time is so offensive please ignore it.
Benderff is offline
post #9 of 33 Old 08-29-2010, 06:17 PM Thread Starter
bmxrules39
The thing that really sold me on long arms was when I was doing the golden crack in Moab, my driver front was all the way down in and I was trying to move forward, it felt like something was weird so I really watched that tire. As i moved forward the tire was actually trying to push down into the crack instead of rolling up it, I kept inching forward and it finally popped up over. It wasn't dangerous or intense, but watching it really made me realize that if my arms were on less of an angle it probably would've rolled through a lot smoother. I'm sure this has happened in other situations that I haven't realized as well.
I'm also looking for the better on road ride, and not so much inward movement when I'm flexing
§wHitt§
post #10 of 33 Old 08-29-2010, 06:22 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Maybe you should figure out your shock lengths and run a swaybar?
I am Savvy
mrblaine is offline
post #11 of 33 Old 08-29-2010, 06:23 PM Thread Starter
bmxrules39
blaine you're not worth arguing with, i was actually hoping you'd find this and have something to input. but I'm not sure what a shank is? Is that another word for a johnny joint? Sorry I haven't been at this as long as you I don't know all the lingo and can't see every angle of everything without some help, isn't that why this forum is here?
§wHitt§
post #12 of 33 Old 08-29-2010, 06:29 PM Thread Starter
bmxrules39
you almost make it sound like it would be a bad idea to go long arm, or mid arm or change it at all. I'm sure a sway bar in the golden crack wouldn't be a better alternative than having long arms, and I haven't really found it worth while to fork out the money for a Currie anti rock, while it would be sweet I can't see it solving too many issues.
§wHitt§
post #13 of 33 Old 08-29-2010, 06:37 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Alright, let me see if I can help. The problem with your current JJ's is they have a 1" threaded section that screws into the tube and that's called the shank.
If you increase the length of the arm, it's very possible to land on a rock close to the frame side of the arm end and the leverage from the spring pushing down will bend the shank. You need to increase the shank diameter to the larger 1 1/4" versions if you increase the arm length.
Currently you have no issues because the length of the arm is a short enough lever that it's pretty difficult to bend the threaded shanks.
I am Savvy
mrblaine is offline
post #14 of 33 Old 08-29-2010, 06:39 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I can see no reason for 99.9% of the TJ's out there to ever run long arms. Long being 36-38" or longer.
I'm a huge fan of 26-28" arms and even then the 1" shanks are not ideal.
I'm sure you don't know that an Anti-rock helping to pick up that tire in the crack would be a bad idea. If you've never wheeled with one, try and limit your assumptions about how much they really do help.
I am Savvy
mrblaine is offline
post #15 of 33 Old 08-29-2010, 06:47 PM Thread Starter
bmxrules39
I think it's more of a- completely had no idea rather than an assumption, but it does make sense now that you bring it to my attention.
So then a shank is the diameter of the threads coming off the joint. Why is it that they are ok to run with a short arm setup? Or do you not like them even then?
§wHitt§
Goodbye Long Arms... hello short arms Robert J. yates TJ Wrangler Technical Forum 730 06-26-2015 03:23 AM
Looking for tips on adjusting long arms/radius arms ElementX TJ Wrangler Technical Forum 7 08-05-2010 10:36 PM
Currie lower arms shorter than my old arms? vetdezracer TJ Wrangler Technical Forum 17 12-04-2009 05:13 AM
Short arms w/ tummy tuck, or long arms? P89Jeeper TJ Wrangler Technical Forum 5 08-16-2008 05:47 AM
Long Arms w/ rear Radius arms? YellowNJTJ02 TJ Wrangler Technical Forum 22 12-06-2006 08:20 AM
