Skyjacker Upper Control Arms - JeepForum.com
post #1 of 5 Old 10-15-2005, 02:13 PM Thread Starter
4thduck
Tired of that banging noise under my rig from worn out heim joints on my skyjacker control arms what are the upper control arms for any way can I just remove them and move on? Any one have ideas on a fix? I converted to the Tereflex Heim replacements on my lower control arms these are greasable and rebuildable but still wondering if I can just remove the uppers.
4thduck is offline
post #2 of 5 Old 10-15-2005, 02:25 PM
phish832
phish832's Avatar
To be honest i dont think you can remove the uppers, i believe those are there esp. to keep the axle all in alighnment with the jeep.
i esp. woundnt do this if you drive it on the street...
2004 Rubi, 5.5" RE TL LA, Bilstein 5100's, 35" Pitbulls, RCV's, Currie AR, Warn Zeon
2013 GC HEMI
2015 Duramax
phish832 is offline
post #3 of 5 Old 10-15-2005, 03:33 PM
BNovak
BNovak's Avatar
replace them with some from Nth Degree. think they are like 140 a pair or something.
_BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #4 of 5 Old 10-15-2005, 08:35 PM Thread Starter
4thduck
Nth Degree
Looks like a winner! I like the bushing set up much more than the Heim set up.
I also took a look at the quick disconnect system not bad not bad at all.
thanks BNovak
4thduck is offline
post #5 of 5 Old 10-16-2005, 12:51 PM
phish832
phish832's Avatar
do those or look into fourreal steal control harms......good quality!
2013 GC HEMI
2015 Duramax
phish832 is offline
Skyjacker upper arms 'clunking' kuebelwagen TJ Wrangler Technical Forum 6 11-09-2009 06:35 PM
Skyjacker rear control arms MDOC111 TJ Wrangler Technical Forum 1 07-14-2009 07:15 PM
Skyjacker Adjustable Front Upper Control Arms DeepSky JK Wrangler Technical Forum 6 04-01-2009 04:17 PM
Skyjacker Std. Control Arms jonster TJ Wrangler Technical Forum 4 10-26-2005 05:49 PM
Skyjacker Control Arms mossimo19 TJ Wrangler Technical Forum 13 08-17-2005 05:19 PM
