Skyjacker lift questions? - Page 3 - JeepForum.com
post #31 of 39 Old 05-14-2013, 12:11 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Originally Posted by McLovin View Post
If you want your axles centered buy adjustable track bars, track bar brackets are just a band aid.
Not true and the front track bar does perfectly fine with drilling a new hole (if you know what you're doing).
TheBoogieman is offline
post #32 of 39 Old 05-14-2013, 12:55 PM
Imped
Imped's Avatar
I added a 1.5" spacer on the low side and ..................NO DIFFERENCE!
I question your ability to use a tape measure.
OlllllllO
IndyORV
Imped is offline
post #33 of 39 Old 05-14-2013, 01:12 PM
FingerTight
If a nice ride is what you're after I can't recommend the OME springs / shocks enough. Picked these up from Rokmen a week or so ago and they've made a truly stunning difference in ride over the old RC set that was on there.
FingerTight is offline
post #34 of 39 Old 05-14-2013, 05:03 PM Thread Starter
mnm99
What's your exact setup? Sway bar extensions? track bar ect...
mnm99 is offline
post #35 of 39 Old 05-14-2013, 07:21 PM
Bear6
Does anyone know if you can pass inspection having more than one lift kit? I have a 4 inch suspension and 1 inch body. I'm being told this will not pass inspection in maryland.
Bear6 is offline
post #36 of 39 Old 05-14-2013, 07:50 PM
tyvanwie
Dude, don't post this on every thread. Start your own.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #37 of 39 Old 05-15-2013, 11:23 AM
FingerTight
Part numbers for you
OME2934 front coils
OME2949 rear coils
OMEN66 front shock
OMEN67 rear shock
Stock sway bars, home brew (previous owner) front discos that look to be extended, not sure on rear sway connections (guessing the old RC lift had an extension), front track bar / steering look to be Currie setups (PO installed), rear track bar appears stock. Total lift is supposed to be ~ 2.5", frame is about 19" off the garage floor w/33s. I know Rokmen chose those springs based on the accessories (bumpers, winch, etc). Rides down the street like a cloud of marshmallows
post #38 of 39 Old 05-15-2013, 02:44 PM Thread Starter
mnm99
OME2934 front coils
OME2949 rear coils
OMEN66 front shock
OMEN67 rear shock
Post some pictures! Please...
mnm99 is offline
post #39 of 39 Old 05-20-2013, 06:51 PM
FingerTight
