Skyjacker Lift Install Questions - JeepForum.com
post #1 of 10 Old 02-15-2011, 09:43 AM Thread Starter
Pappy1
I'll be installing a Skyjacker lift on my '03 TJ next week. I was reading over the instructions and it doesn't say that a spring compressor is needed. Will the springs come out without compressing them? Also I heard a couple of years ago that the bushings in the Hydro shock weren't any good. Is that still a problem?
Pappy1 is offline
post #2 of 10 Old 02-15-2011, 09:59 AM
ff33
Yes they will come out w/o compressing them, you just need to droop the axle down far enough to get them out, your new springs I'm assuming are longer so when you go to put them on you will have to droop the axle a little further down as well.
2006 Rubicon LJ, auto, 2" lift, 1.25 bl, mml, tt, armor, winch, 33's, that's it for now.
ff33 is offline
post #3 of 10 Old 02-15-2011, 10:34 AM Thread Starter
Pappy1
Got it! Thanks a bunch.
Pappy1 is offline
post #4 of 10 Old 02-15-2011, 10:43 AM
jabroni3411
rent a spring compressor from auto zone, makes things a million times easier. ask me how i know
Check My Build
jabroni3411 is offline
post #5 of 10 Old 02-15-2011, 11:00 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
How do you know that without him telling you how much lift it is? Try doing that with 4-6" springs without spring compressors.
TheBoogieman is offline
post #6 of 10 Old 02-15-2011, 11:04 AM
TheBoogieman
Disturbed
That depends on the lift size and the bushing thing was fixed years ago.If you're doing a 3" lift or more,rent (FREE)a set of coil STRUT compressors or it's going to be a PITA without disconnecting the control arms in the front.The rear is a piece of cake.
post #7 of 10 Old 02-15-2011, 11:16 AM
ff33
For the part you quoted me on I was refering to him removing the stock springs since that is what most people are removing when they go for a lift, as far as putting new springs in I should have been more specific, and the above post cleared that up.
ff33 is offline
post #8 of 10 Old 02-16-2011, 06:32 AM Thread Starter
Pappy1
It's a 3" lift, I understand what you guys are saying about no problem getting stock springs out but getting new springs in may need to be compressed if i can't getting axle dropped far enough. Thanks guys!
Pappy1 is offline
post #9 of 10 Old 02-16-2011, 08:50 AM
TheBoogieman
Disturbed
The rears will go in no problem and the fronts should too.It never hurts to get the coil strut compressors just in case.
post #10 of 10 Old 02-17-2011, 07:18 AM Thread Starter
Pappy1
Alright Boogieman will do. I'll rent compressors before I "park" the jeep. Thanks!
Pappy1 is offline
In the middle of my 4inch skyjacker lift install kb1kzd TJ Wrangler Technical Forum 5 02-28-2010 04:10 PM
A few questions about lift after install. N2SPD TJ Wrangler Technical Forum 1 05-11-2009 08:54 AM
Lift kit install questions jake92321 TJ Wrangler Technical Forum 9 04-26-2009 07:23 PM
RE Lift Install Questions jeepyjpsu YJ Wrangler Technical Forum 1 04-27-2008 12:22 AM
2 1/2 Skyjacker Lift Install Jeeper-4-Life TJ Wrangler Technical Forum 3 02-05-2004 08:36 PM
