Skyjacker 4" Value Flex Sport Lift Kit with Hydro Shocks - JeepForum.com
post #1 of 12 Old 07-22-2010, 01:19 PM Thread Starter
JeepJeep04
Does anyone know anything about this lift? We have a 2003 Jeep Sport we are looking to lift. Planning on putting on some 33s.
Skyjacker Suspension TJ403BPHX - Skyjacker 4" Value Flex Sport Lift Kit with Hydro Shocks for 03-06 Jeep® Wrangler TJ & Unlimited - Quadratec
If this is not a good lift to go with, then what are some recommendations? We had also thought of doing a 3" suspension and a 1" body lift.
JeepJeep04 is offline
post #2 of 12 Old 07-23-2010, 12:31 AM
bojang
No. As a general rule of thumb, stay away from anything with skyjacker on it.
There are better options available, for around the same money or even less, that are better quality lift kits.
What are you planning to do with your jeep? That would help a ton, as would filling out your profile.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
post #3 of 12 Old 07-23-2010, 05:43 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
The shocks are very good and inexpensive.I would go with a 2.5-3" SL and a 1" BL for 33's and way less problems and parts.Try RC,Zone also.
TheBoogieman is offline
post #4 of 12 Old 07-23-2010, 06:07 AM
fang_x
i had a similar kit installed on my jeep, it was fine. great for the price. Offroad it performed well. Much better then stock.. I dont know why people are hate ing on Skyjacker ?
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #5 of 12 Old 07-23-2010, 06:30 AM
Jetscuh
O rly?
2015
I had a 4 inch Skyjacker suspension in my TJ for a couple of years. It wasn't bad. I think the Hydro shocks are a good bang for the buck.
The only think I'd recommend is repainting the shocks or adding some more clear coat because the paint Skyjacker uses isn't the most durable. This goes for lower control arm paint (mine peeled off) too. I do live in the rust belt so it might be a little worse up here but a couple cans of paint and an hour of your time isn't so bad.
I do think with Skyjacker it's getting to the point where you're just paying for the name. They could stand to upgrade a few things. I'd keep it on your list and shop around. Just to ensure you're getting the best quality for the amount of money you want to spend.
If I were to do a 4 inch short arm suspension again, I'd probably look into going with Currie.
Jetscuh is offline
post #6 of 12 Old 07-23-2010, 06:31 AM
TheBoogieman
The same reason that they hate on RC,they've never owned the lift.
post #7 of 12 Old 07-23-2010, 06:37 AM
Jetscuh
O rly?
2015
In certain cases, you don't have to own the lift to know how well or how poor it operates.
Sometimes it can be seen just by evaluating the components, type of material used and the geometry of the design.
Jetscuh is offline
post #8 of 12 Old 07-23-2010, 06:53 AM
RowJ
My TJ has a 2.5" Sjyjacket lift and I'm pleased.
I have not owned it long but the lift has thousands of miles on it. I've looked it over carefully and it appears to be good quality and holding up well.
I do know the Shyjacker lifts on heavier, 4 ton, vehicles (Dodge diesel P/U's) do not hold up well under racing/towing conditions.... but I can see nothing negative to report on their lifts for a 2 ton Jeep. Looks to me like they have that package figured out.
Skyjacker prices are higher, but I don't know enough about other lifts to know if there is higher quality??
RJ
RowJ is offline
post #9 of 12 Old 07-23-2010, 07:11 AM
TheBoogieman
Sometimes people just repeat what they've heard.
post #10 of 12 Old 07-23-2010, 09:18 AM
longbluerubi
I have skyjacker 2" coil spacer and hyrdo 7000 shocks. Was on the jeep when I bought it. They seem to be doing OK, have been offroad a few times, no problems. The shock casing is pitting as mentioned earlier. When I replace/go higher I probably won't use skyjacker though.
'05 LJ Unlimited Rubicon
I6 4.0L manual 6-speed
OME 2.5" lift+Nitrocharger Sport shocks
1" BL, JKS adj front & rear trackbars, JKS discos
33" BFG A/T
longbluerubi is offline
post #11 of 12 Old 07-23-2010, 09:21 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
no, not on jf......
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #12 of 12 Old 07-23-2010, 09:43 AM
TheBoogieman
Originally Posted by jeepinmichguy_ View Post
no, not on jf......
Shocking,isn't it.
skyjacker , lift kit , TJ , wrangler
Skyjacker 2" lift with hydro shocks bozhoz TJ Wrangler Technical Forum 4 02-16-2011 04:50 PM
2.5" OME Springs with Skyjacker Hydro shocks ChrisTJCO TJ Wrangler Technical Forum 22 05-25-2010 02:22 PM
Skyjacker 2" Lift with Hydro Shocks PSYCH0 TJ Wrangler Technical Forum 58 12-28-2008 02:28 PM
2" Skyjacker Hydro Shocks!!?? Thug Nasty TJ Wrangler Technical Forum 3 07-16-2006 12:51 PM
skyjacker 4" softride w/ Hydro shocks... jackal TJ Wrangler Technical Forum 3 04-23-2004 04:18 PM
