Skyjacker 2'' BB questions - JeepForum.com
post #1 of 7 Old 09-18-2011, 04:31 PM Thread Starter
BMTH2010
Just picked up a Skyjacker 2'' BB with Hydros for a great price. Going to be installing it one my newly purchased 06 LJ Rubi. The recommended tire size is a 32 but I've seen a few different members running 33s and 285s with similar lifts. I would like 285s so my question is what do I need to do to make this happen?
BMTH2010 is offline
post #2 of 7 Old 09-18-2011, 04:36 PM
threeb
The 2" will house 33s. If you plan on off roading I would add a 1" body lift and make sure you have proper bump stomps.
LJ Owners Group member #431.
threeb is offline
post #3 of 7 Old 09-18-2011, 05:11 PM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
Do a 1.25" BL.A 2" lift isn't enough for 33's if you drive it out of the mall parking lot.
TheBoogieman is offline
post #4 of 7 Old 09-18-2011, 05:30 PM Thread Starter
BMTH2010
I've been looking into the JKS 1.25'' BL and MML. Seen any on sale anywhere?
BMTH2010 is offline
post #5 of 7 Old 09-18-2011, 05:38 PM
Jasons4x4
Do you have stock wheels? If so you will have rubbing issues during cornering. I had 32x11.5x15 tires on a 2" budget lift and had slight rubbing on the swaybars when the steering wheel was cut all the way one way or the other but had no problems with the tires getting into the fenders on or off road (note I did not have swaybar disconnects at the time). If you don't have swaybar disconnects you might be able to get away without rubbing/clearance issues in the fenders but I'm not 100% sure. You can clear the swaybar rubbing issues by either installing wheel spacers or aftermarket wheels with more offset. You could also run the 1.25" body lift as mentioned before if you're afraid of destroying your fenders, plus the BL gives you room for a tummy tuck down the line.
Jasons4x4 is offline
post #6 of 7 Old 09-18-2011, 05:42 PM
biffgnar
biffgnar's Avatar
The BL will help keep wheels out of fenders but it doesn't do anything for the swaybar (or control arm) rub that comes from the wider tire.
biffgnar is offline
post #7 of 7 Old 09-18-2011, 05:48 PM Thread Starter
BMTH2010
Running Moabs. Wheel spacers?
BMTH2010 is offline
lj , rubicon , skyjacker
Skyjacker = Bad ucfgto Wrangler General Discussion 13 07-12-2011 04:13 PM
Skyjacker 2" spacer kit questions. natedawg87317 TJ Wrangler Technical Forum 3 02-25-2011 05:46 AM
Skyjacker Lift Install Questions Pappy1 TJ Wrangler Technical Forum 9 02-17-2011 06:18 AM
Why not Skyjacker? RichardBailey TJ Wrangler Technical Forum 19 04-25-2007 09:08 AM
srb~AA or Skyjacker Dangle TJ Wrangler Technical Forum 21 02-11-2005 06:34 AM
