Skid thread stripped -- Helicoil or ??? - JeepForum.com
post #1 of 7 Old 08-21-2004, 03:02 PM Thread Starter
Jack Flesher
I have one hole stripped for my skid. My first thought is a helicoil. But then figured with my body lift I could easily drill through the top of the frame rail and run a longer bolt with a nut up top.
Thoughts or any other ideas?
TIA,
Jack
97 TJ, 4.0 5sp, 4:1 TC, 2-low, SYE, 3.5" RE Superflex, 1" BL, Belly-up skid, D44 Tru-Lok F&R, 4:11's, 33's
Jack Flesher is offline
post #2 of 7 Old 08-21-2004, 03:16 PM
RMeak
1955 CJ5
If you can drill thru then that would be cheaper than Helicoil but double check and make sure there are no wires or anything else in the way.
2007 JK Unlimited
1955 CJ5
RMeak is offline
post #3 of 7 Old 08-21-2004, 03:26 PM
igofshn
Locked @ both ends
igofshn's Avatar
Just get a tap and retap it. It should work fine.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 7 Old 08-21-2004, 04:06 PM Thread Starter
Jack Flesher
Yeah, thought of that too and tried it, but there's not enough material left to tap...
post #5 of 7 Old 08-21-2004, 04:09 PM
igofshn
Locked @ both ends
igofshn's Avatar
Tap it a little bigger and get a new bolt. It is 1/2", try one size bigger.
igofshn is offline
post #6 of 7 Old 08-21-2004, 05:18 PM
dakuda
Admin
dakuda's Avatar
I don't know if this is 100% true, but it makes sense to me:
If you drill all the way through the fram, then tighten a nut and bolt to it, you will wind up weakening the frame. So I hear. Something about it compresses the frame, then you think the bolt is loose, so you tighten it more down the road, etc etc. Ultimatly, it is bad for the frame.
Can anyone verify this?
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #7 of 7 Old 08-21-2004, 08:21 PM Thread Starter
Jack Flesher
Thanks guys -- I decided to do it right and bought the helicoil kit. First repair is pretty expensive, but all the rest will be cheap
Anybody in the Bay Area needs a 1/2x13 helicoiled, I got the stuff to do it
stripped gas tank skid mount yarmish TJ Wrangler Technical Forum 3 11-21-2009 03:37 PM
Bolt Thread Stripped Danegerous TJ Wrangler Technical Forum 6 04-23-2009 11:27 AM
Helicoil for Stripped Front Caliper?? gtospeeding TJ Wrangler Technical Forum 22 09-08-2007 10:50 AM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 06:46 AM
Stripped thread leenok YJ Wrangler Technical Forum 3 09-09-2006 08:24 AM
