Skid Plate Transmission Mount Question - ? - JeepForum.com
post #1 of 5 Old 04-29-2011, 04:13 PM Thread Starter
man44a
I was wondering if it's normal for the transmission mount screws to be in a different, slightly angled location now after doing a 1" MM lift. I'm thinking it's probably normal as the entire angle is changed, but I can't find any reference to it in the install tutorials.
man44a is offline
post #2 of 5 Old 04-29-2011, 06:14 PM
Thean
Is this while there are no nuts on it?
Usually they will shift location compared to the original.
Thean is offline
post #3 of 5 Old 04-29-2011, 06:41 PM Thread Starter
man44a
Yeah, with no nuts on. I was having trouble getting to them because of the angle.
man44a is offline
post #4 of 5 Old 04-29-2011, 07:25 PM
Thean
Are you running a stock crossmember mount or did you swap to something like the prothane?
Usually the stock crossmember mount has enough deflection for the studs to protude pretty evenly.
However, the prothanes are so stiff it has a tendancy to not flex & requires some verbal abuse before being able to get them started.
Personally if you have the prothane (or polyurathane equivalent), I would toss it. I ran one for a short while & the vibration through the jeep was so horendous I about stopped driving it until I got a decent rubber replacement.
Thean is offline
post #5 of 5 Old 04-29-2011, 08:11 PM Thread Starter
man44a
I have the Brown Dog Ultraflex Rubber mounts. They are called rubber but man are they giving me the vibs! Thanks for the help. I think I'm going back to factory rubber mounts and spacers.
man44a is offline
Skid Plate/ Tranny Mount Question brentd711 YJ Wrangler Technical Forum 4 10-03-2010 08:13 PM
Skid plate and transmission question. jhf56 TJ Wrangler Technical Forum 4 07-09-2010 11:25 PM
Transmission to skid plate mount champelite210 YJ Wrangler Technical Forum 1 09-21-2008 05:10 PM
Snapped a transmission mount bolt on T-Case skid plate blueteej TJ Wrangler Technical Forum 2 04-06-2007 06:19 AM
help. Snapped transmission mount to skid plate bolt! ClemsonJeepGC TJ Wrangler Technical Forum 15 04-23-2006 08:11 PM
