Skid Plate Protection: A Master List of Types, Companies and Important Considerations
#16 | |
If you want to copy and paste my text into one of your place holding posts, I'll delete mine. This way you can organize it any way you want and it'll be at the top.
#17 | |
Satan Built My Jeep
i did notice that altho your engine skid is restricted to certain years and engines , they make a full line that covers all TJ's. important info in this case and to include in a review if you have one in that section. thanks for your help
"If you don't have time to do it right, you are going to need time to do it over."
'05 Red Flame TJ Rubi UnLtd Are You Legal?----> State by State Vehicle Equipment Laws Thread<----Look Up Your State! Shopping for Armor?---->Skid Plate & Body Protection Thread<----Compare Options! "Teach a man how to take his doors off and he will enjoy his Jeep for a day, teach him to search the forums and he will enjoy his Jeep for life!" |
#18 |
I have:
Extreme Metal Products TJ Steering Box Skid *3/16 Thick Steel *Laser Cut & Powder Coated Black *Self Tapping Bolt Provided *Protects Steering Box on 97 and newer Jeep TJ Series I'm also considering by Extreme Metal Products: 1) TJ Gas Tank Skid *Raises Tank 1" *3/16 Thick Steel *Laser Cut & Powder Coated Black *Uses Factory Hardware *97-02 Does Not Require Body Lift 2) TJ Belly Skid *Increases Ground Clearance by 1" *1/4 Thick Steel *Laser Cut & Powder Coated They sell their skids on eBay and go for less than any other skids I've seen. Quality lokos great and compares to Warn skids. www.extrememetalproducts.com Last edited by ATL TJ; 05-09-2007 at 04:47 PM.. |
#19 | |
Satan Built My Jeep
i was just looking at their site and think some of the stuff id made by them some is just being resold, i'll have to look more later. thanks i'll add them to the list after i figure that out, unless you want to help out a bit more and get that info for me. I would like to have it so i am manufacturers rather than stores. otherwise we have repeats and confusion
#20 |
medic link
T-case fits 03 and up TJ's and has mount to relocate locker pump on Rubicon's. 1/4" thick. A 1" MML and BL are required. has holes in the right places to drain things. he also has 1/4" thick engine skids for 97 and up TJ's that covers oil-pan, transmission and bell housing. Mounts in front to motor mounts from underneath, and can be fitted to many t-case skids including factory. also sells lower control arm bracket skids as well. Surprised you don't have it listed already actually ![]()
78 CJ5 04 TJ "U" package 06 XK Commaddy Jeep mods do not fix poor driving or stupidity. |
#21 | |
Satan Built My Jeep
just what i was looking for, thanks for getting the info so good, don't be surprised that they was not listed, you had not wrote in yet and there are a lot of good ones that i have not listed yet, i just started today
#22 |
Off topic - shouldn't this be in the review section?
05 TJ 4.0, RE 3.5" SuperFlex, 35x12.50x15 Baja Claws, Viair 450c OBA, Dana 30/44 w/ 4.56 gears, TruTrac F/R, Herculiner, Warn 9000i, RockHard Rear Bumper w/ tire carrier and gerry can, KC Slimlites, AirRaid, custom short exhaust, 400watt DC-AC converter, Kilby gas tank skid, Rock-It diff sliders |
#23 | |
Satan Built My Jeep
#24 | |
hodophobic
well these aren't really reviews...more like an answer to nearly all skid plate related questions that get asked...
instead of saying "search is your friend," we'll be able to post a link to this thread. thanks atl, i was about to buy a kilby gas tank skid, you saved me some $$$
Bestop LJ Halftop for sale. Warm up the cabin faster in the winter! Jeepiki, the Wiki just for Jeeps You can't argue with ignorance. Quote:
#25 | |
Satan Built My Jeep
i love when it works, glad you found good info! and yeah that is just in the beginning , that is what what i an looking to do
#26 | |
hodophobic
oh check out Gen-Right
http://www.genright.com/category.aspx?categoryID=20 they're pretty much a copy of kilby though, but still a different brand
#27 |
Here's a couple of skids that have held up pretty good:
1. Four X Doctor Diff Guard for the Dana 30. Diff cover does not need to be taken off for installation. Fits the follwing vehicles: 97-06 Jeep Wrangler (TJ) 87-95 Jeep Wrangler (YJ) 04-06 Jeep Wrangler Unlimited (TJ) http://www.quadratec.com/products/92023_001.htm 2. Fabtech Steering box skid plate: Fabtech's 1/4" thick steel skid plates. Heavy duty one piece welded design bolts directly to your frame in minutes. Available in black powder coat finish only. Also bolts into Fabtech front bumper. http://www.quadratec.com/products/16119_300.htm |
#28 | |
Satan Built My Jeep
do you have manufacturer links for either of these , i do not want to link to a secondary store, unless they are the sole distributor of the brand. and store link get out dated real fast, they change all the time
#29 |
Here ya go. With the manufacturers links
1. Four X Doctor Diff Guard for the Dana 30. Diff cover does not need to be taken off for installation. Fits the follwing vehicles: 97-06 Jeep Wrangler (TJ) 87-95 Jeep Wrangler (YJ) 04-06 Jeep Wrangler Unlimited (TJ) http://www.fourxdoctor.com/main/diff_guards/diff_guards.html 2. four X Doctor Gas tank skid. Run 3/16" sides, with 6 cut outs for drainage. You also gain 1" of ground clearance, and about a 1/4" to more from the differential. We have also moved the skid to the passenger side of the jeep for more driver side shock clearance. http://www.fourxdoctor.com/main/tank_guard/tankskid.html 3. Fabtech Steering box skid plate: Fabtech's 1/4" thick steel skid plates. Heavy duty one piece welded design bolts directly to your frame in minutes. Available in black powder coat finish only. Also bolts into Fabtech front bumper. http://www.fabtechmotorsports.com/pdfs/instructions/FT94001i%20Instruction%20Sheet.pdf |
#30 | |
Satan Built My Jeep
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
