Quantcast ski rack options spare tire or roof rack - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > ski rack options spare tire or roof rack
TJ 5.25" Speaker Adapters - NalinMFGTruck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 11-12-2009, 09:44 PM   #1
Therou
I have a 97 TJ and am looking to figure out a rack for the ski season. I am also an avid camper so something that can serve both purposes would be nice. I have seen some of the racks that can flip out to make a canopy that are really nice, but way to $$. I am looking for an affordable option (under 400) and it would be nice if there was a Canadian supplier to save on shipping.
Thanks in advance for any suggestions.
1997 TJ Emerald Green Pearl 4L 6Cyl 26X XXX KM
Green Jeep Club Member #190
NGJC #8
Canadian Jeep Club Member #15
Stock Jeep Member #55
www.therou.ca
Therou is offline   Reply With Quote
Old 11-12-2009, 09:51 PM   #2
Unlimited04
Unlimited04's Avatar
roof rack the ski/snowboard on the hard top.
you can use a junkyard rack off an late model XJ, ZJ or late 90s Ford Explorer. or bolt on Yakima or Thule gutter mounts.
mine:
Unlimited04 is offline   Reply With Quote
Old 11-12-2009, 09:53 PM   #3
Therou
Well I would do that if I had the roof rack, that's why I am looking for suggestions on what rack to go with.
NGJC #8
www.therou.ca
Old 11-12-2009, 09:55 PM   #4
Unlimited04
i dont have a roof rack.
Old 11-12-2009, 10:01 PM   #5
Therou
sorry when I looked at your post all it had was "roof rack the ski' " must have been a hiccup on the forum. how well does it connect to the gutter?
NGJC #8
www.therou.ca
Old 11-12-2009, 11:05 PM   #6
87warrior
Check out this picture thread. A few different options you could explore:
http://www.jeepforum.com/forum/f59/tjs-roof-racks-860724/
I am very pleased with my Yakima hardtop rack system. Works perfect. The Towers and cross bars can be removed when you do not need to haul skis around. I was a bit nervous about drilling in the hard top, but it was pretty painless. 2 years later I have no regrets and it is still water tight.
In hindsight, I would rather have gone with the Junkyard rack system, because it would be a lot cheaper. Grab the rack tracks, towers and rails from any vehicle, cut to fit your hard top, measure twice and drill.
03 Rubicon(Rubicon build)
92 Comanche (92/99 Comanche Project)
87warrior is offline   Reply With Quote
Old 11-13-2009, 08:01 AM   #7
shotgunsmith
I bought an inexpensive roof backet and bolted it straight to the top. I just bungee the skis to that and a have extra gargo space for other stuff. I didn't want a single purpose rack.
"If a law is stupid, you have to break it."
HST
shotgunsmith is offline   Reply With Quote
Old 11-13-2009, 08:04 AM   #8
Unlimited04
connects fine, i can shake the crap outta the jeep. you gotta be real careful when installing them tho, the clamps could slip off the plastic, or the plastic could break. i use 1/16" rubber padding to aid in traction of the clamps. major downside is the spacing is very short. i intend to do the XJ roof rack (already have it) or that Yakima rail system later down the road. the yakima route is uber-expensive tho.
Old 11-13-2009, 08:10 AM   #9
robtre
I need an option for a soft top, and Ive seen Spare tire ski/snowboard attachments but I dont know where to buy them.
His:2005 Wrangler Rocky Mountain Edition
Hers:2005 Grand Cherokee Laredo
robtre is offline   Reply With Quote
Old 11-13-2009, 08:50 AM   #10
rainmn
Thule makes a spare tire mount bike rack called the Spare Me, for which they also sell an optional attachment to convert it to a ski / snowboard carrier.
I've never tried it, so I can't tell you if it's any good or not.
rainmn is offline   Reply With Quote
Old 11-13-2009, 08:53 AM   #11
Unlimited04
I bought a Thule 987xt and thought it would work...ended up hating it and sold it.
But it will attach to a bike rack on a spare: http://www.thuleracks.com/product.asp?dept_id=9&sku=987xt
Old 11-20-2009, 05:54 PM   #12
Therou
I am planning on going to the junkyard tomorrow morning, but was wondering what most of the old roof racks on xj's zj's or even some old minivans are hooked on with? Torx? bolts? screws?
NGJC #8
www.therou.ca
Old 11-21-2009, 10:10 PM   #13
Therou
So I ended up getting a rack off a minivan. I need to cut down about 6 inches before I can start to install it. Probably do it in a couple weeks when I am home with the tools. Pics will follow. Now just need to get the actual ski holders.
NGJC #8
www.therou.ca
Old 01-03-2010, 10:24 PM   #14
Therou
So I finally got this project finished. I ended up grabbing a roof rack from a minivan. I cut the rails about 6 inches shorter so it would fit on the hardtop. I then drilled the holes through the hardtop using the rack as the template. To connect it I used bolts with a rubber washer, metal washer and a nut. I also put a thick bead of marine grade silicon between each washer and the top. In about a week I will tighten the nuts one last time and put a layer of the silicon over the whole nut as one last protection against leaks.
It was a pretty simple project. Finished it off with a "sportrack" ski rack that just clamps on the roof rack. I will try and get some pictures next ski trip.
NGJC #8
www.therou.ca
Old 01-03-2010, 10:39 PM   #15
60AnniversaryTJ
Junior Member
60AnniversaryTJ's Avatar
Pic's! I've been wanting to do the junkyard rack too. Tried the Thule spare tire system and hated it.
Silver Jeep Club Member #45
'01 TJ 4.0 5spd D30 D44 31x10.50x15 discos
60AnniversaryTJ is offline   Reply With Quote
Glock Forum
